Bandwidth Analyser Tool
pushpak.lele
Is there any software tool available to
analyze traffic flowing on wan link ?
Also badwidth utilized by application ?
and will the result be real time ?
please help
regards
pushpak
gold4ever2
you can try NetLimiter is good software to measure the bandwidth at application level
Joseph W. Doherty
If the device is a Cisco router, and if it supports NBAR protocol discovery, that will provide bandwidths used recently by various applications. (NB: It doesn't know every application but you can also get it to give you a breakdown of traffic it doesn't know by port usage. You can then manually define other applications.)
Mohamad Qayoom
Level 3
Level 3
Hi Pushpak,
You can use Cacti for this purpose.
Here is a link for you :
http://www.cacti.net/
Mohamad
Leo Laohoo
Packet analyzer = Wireshark (freeware), OmniPeek (with VoIP)
Bandwidth Analyzer = MRTG, CyberGauge, Solarwinds Engineer's Toolset
