Bandwidth Calculation from rx tx value
Ninad Thakare
Level 2
Level 2
Can any one help, how to calculate bandwidth utlization from " sh int" details..?
Can the percentage will get calculated from rx tx values..?
I am using 4 mbps lease line.
FastEthernet0/0/0 is up, line protocol is up
Hardware is FastEthernet, address is 001a.6c70.4b14 (bia 001a.6c70.4b14)
Description: Internet Connection
Internet address is 1.1.1.1/30
MTU 1500 bytes, BW 4000 Kbit, DLY 100 usec,
     reliability 255/255, txload 31/255, rxload 120/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 828000 bits/sec, 111 packets/sec
5 minute output rate 498000 bits/sec, 92 packets/sec
     788931865 packets input, 4036778275 bytes
     Received 398 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     571607354 packets output, 3639639717 bytes, 0 underruns
Thanks in Advance,
Ninad Thakare
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
There are several ways to do this, but if your link is 4 Mbps, use the bandwidth statement on the interface and set to 4000 (I think I recall it uses K, if not correct value would be 4000000).
Then when you looks at tx or rx loads, those are the load ratios.  e.g. 128/255 = 50%, 64/255 = 25%.
6 Replies 6
Sandeep Choudhary
HI Ninad,
I think you have got the picture.
This is the volume of traffic for that time period.
first of all change the input rate to 30 seconds.
config t
load-interval 30
exit
then use
sh int f0/1 | inc drops|bits
it will show you how much trafic going through or any packet drops as well.
Please rate helpful posts
Hi sandeep,
I changed have changed the load interval to 30. And found the following output.
  Internet address is 115.111.129.54/30
     reliability 255/255, txload 20/255, rxload 178/255
  30 second input rate 2648000 bits/sec, 282 packets/sec
  30 second output rate 329000 bits/sec, 187 packets/sec
     807938619 packets input, 3336210079 bytes
     Received 400 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     584946689 packets output, 2374024442 bytes, 0 underruns
     0 output errors, 0 collisions, 4 interface resets
     1 lost carrier, 0 no carrier
Now how should i calculate...?
Ninad Thakare
Hi Ninad,
There are some free and commecial network monitoring software packages that can give you much more data about in/out traffic on your device.
please rate helpful posts
Joseph W. Doherty
Disclaimer
Posting
Thanks for help. I got the logic behind it.
Thanks everyone.
Ninad Thakare
Glad that u got ur answer.
