Bandwidth Limit based on Source IP?
devils_advocate
Level 11
Level 11
I am trying to think of a way to apply a bandwidth limit based upon Source IP subnet.
I need to have the ability to limit both the outbound and inbound traffic.
So I created the following config:
policy-map bw-limit-inbound
 class bw-limit-class
  police 10000
class-map match-any bw-limit-class
 match access-group 150
access-list 150 permit ip 172.16.99.0 0.0.0.255 any
If I apply the Service Policy inbound, it does police the upload to 100Kbps.
If I apply it outbound, it does nothing to the download.
Any reason for this?
I am applying this to an SVI
luckymike33
Level 6
Level 6
You would normally create a QoS policy which shapes traffic, and apply this outbound when you want to limit traffic rates in an outbound direction. i.e.
class-map match-any TEST
match access-group 140
policy-map LIMIT_OUTBOUND
class TEST
shape average 10000
int gi0/0
service-policy LIMIT_OUTBOUND out
i.e. policing - is used inbound, and shaping is normally used outbound - I hope this answers your question?
Very best wishes
Mike
mlund
Level 11
Level 11
You state that inbound works that means that the access-list is OK, it says traffic coming from 172.16.99.0/24 going to any should match
However the return traffic is coming from any going to 172.16.99.0/24, so You have to add that into an access-list.
It will probably work with just adding
access-list 150 permit ip any 172.16.99.0 0.0.0.255
/Mikael
devils_advocate
Level 11
Level 11
Hi Guys
Just to update this thread, I figured out where I was going wrong!
As mentioned by Mikael, the ACL only shows traffic one way, hence why it was not applying the service policy to the download.
I have three subnets I want to Police both outbound and inbound so I started with Three ACLs:
access-list 197 permit ip 172.16.97.0 0.0.0.255 any
access-list 197 permit ip any 172.16.97.0 0.0.0.255
access-list 198 permit ip 172.16.98.0 0.0.0.255 any
access-list 198 permit ip any 172.16.98.0 0.0.0.255
access-list 199 permit ip 172.16.99.0 0.0.0.255 any
access-list 199 permit ip any 172.16.99.0 0.0.0.255
I then created the relevant class maps:
class-map match-all vlan998-download
 match access-group 198
class-map match-all vlan999-download
 match access-group 199
class-map match-all vlan997-download
 match access-group 197
class-map match-all vlan998-upload
class-map match-all vlan999-upload
class-map match-all vlan997-upload
Then the service policies:
policy-map download-limit
 class vlan997-download
  police 2000000
 class vlan998-download
  police 3000000
 class vlan999-download
  police 4000000
policy-map upload-limit
 class vlan997-upload
  police 200000
 class vlan998-upload
  police 300000
 class vlan999-upload
  police 400000
Then finally applied those to the relevant SVI:
interface Vlan102
 ip vrf forwarding WAN2
 ip address 10.20.2.2 255.255.255.0
 ip nat inside
 ip virtual-reassembly in
 service-policy output download-limit
 service-policy input upload-limit
Hello
I have a similliar need to rate limit as devils_avocate outlined above. Am trying to implement on a Nexus 5596 running version 7.3(3)N1(1) with a L3 module. Every think works find till i try to apply the "service-policy" statement to the SVI interface. The syntax is not recognized. Perhaps there is a feature I need to enable ...or it may not be supported on nxos ?
RtRivPD1-1(config-if)# service-policy acl-upload-limit
% Invalid command at '^' marker.
Would anyone have a workaround .
