Bandwidth Limit on cisco router
datamodule
I want to limit bandwidth on one of my WAN router connected interface can you guys share which is best option to do this
Router model cisco 3845
Thanks for your help
JohnTylerPearce
Level 7
Level 7
You can do this in one of two ways.
- Traffic Shaping
- Traffic Policing
Traffic Shaping - Allows you to limit bandwidth usage, by implementing a queue, that holds excess traffic, until it can send traffic.
Traffic Policing - Allows you to limit bandwith by dismissing any traffic that doesn't match your CIR, or if it does, you can dismit it, remark traffic.
Are you wanting to limit traffic from your router to your LAN, or for a specific type of traffic. What is the end goal with this bandwidth limitation?
Hello
Just like to add to Johns post.
Traffic shaping is predominantly for egress traffic -(Usually comes into play on your routers when your physical wan lines exceeds the your traffic rate set by the ISP  or your neighboring site)
Traffic Policing is used for ingress  traffic ( usually originating from you LAN,-entering first device in network from being overrun with too much traffic)
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
