Bandwidth Management For Sub-Interfaces
Ali Hazim
Level 2
Level 2
Is There a Way To Specify Different Bandwidth Size Of Sub-Interfaces, For Example:
If I Had A G0/0 Interface, And I Created 3 Sub-Interfaces G0/0.1, G0/0.2, & G0/0.3. Is There a Way That I Can Manage The Bandwidth So That G0/0.1 = 600Mbps, G0/0.2 & G0/0.3 = 200Mbps Each?
Georg Pauwen
if you use shaping, the below should work:
policy-map GIG_01
class class-default
shape average 600000000
policy-map GIG_02
class class-default
shape average 200000000
policy-map GIG_02
class class-default
interface GigabitEthernet0/0.1
service-policy output GIG_01
interface GigabitEthernet0/0.2
service-policy output GIG_02
interface GigabitEthernet0/0.3
service-policy output GIG_03
Georg Pauwen
policy-map GIG_01
class class-default
policy-map GIG_02
class class-default
policy-map GIG_02
class class-default
Thank You Very Much, You've Answered My Question And Gave Something New To Read About Which Is (Shaping)
on a side note, you want to use shaping as much as possible, and avoid policing and rate limiting whenever possible. Shaping, as the name implies, as opposed to policing, where excess traffic is just dropped, retains excess traffic and reschedules it for transmission at a later time (milliseconds that is).
Have a look at the document below:
https://www.cisco.com/c/en/us/support/docs/quality-of-service-qos/qos-policing/19645-policevsshape.html
