Bandwidth Point
rootadmin
I understand that Cisco 7206 series routers are modular and require to verify the bandwidth point whenever you wanna add in a module card...
Currently, I have a Cisco 3640 series router..Does it have this restriction for bandwidth point or is there such a thing in Cisco 3640?
gaurav.prakash
I dont think there is any issue of Bandwidth points in 3640..
regards,
GP
Thks for the reply....In that case...Do you have any documentation based on this..?
The bandwidth points is solely for the 7200 series as it is specific to its hardware architecture.
http://www.cisco.com/application/pdf/en/us/guest/products/ps341/c1161/ccmigration_09186a008009184d.pdf
HTH,
Mohammed Mahmoud.
Hi..
Thks for the information...Let me go read this PDF file then.. Thank you
