Bandwidth Restraints
rodger rau
Visitor
Existing network, 2 data vlans(A & B), 2 voice vlans...dual circuits (MPLS/Internet).. just upgraded internet circuit from 4m to 50m.  Speedtests from vlan A are OK (47down/47up), however any machine on vlan B are incorrect (3down/17up).. ISP router duplex/speed is set to auto/auto as well as my side.  I have QOS policies setup but only on the MPLS route which is not having an issue.. traceroutes show all traffic taking correct route.  What would it be? Cisco 2911 Version 15.0(1)M5, RELEASE SOFTWARE (fc2)
Please provide configuration of your 2951 and how the devices in vlan A and vlan B (you were using for tests) are connected to the router.
Have you tried to run test on a single laptop connected to single switch's port, but putting it into different VLANs (by soft configuration)?
here is the switch router config.  we are using this for layer 3 connectivity.  Yes, I have tested with a single laptop.. thats how I was able to isolate to just "VLAN B"
version 15.0
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone year
service timestamps log datetime msec localtime show-timezone year
service password-encryption
service sequence-numbers
hostname xxx
boot-start-marker
boot-end-marker
logging monitor informational
enable secret 5 xxx
aaa new-model
aaa group server tacacs+ TACACS-1
 server-private xxx key 7 xxx
 ip tacacs source-interface GigabitEthernet0/0
aaa authentication login default group TACACS-1 line
aaa authentication enable default enable
aaa accounting exec default
 action-type start-stop
 group TACACS-1
aaa accounting commands 1 default
 group TACACS-1
aaa accounting commands 15 default
 group TACACS-1
aaa accounting network default
 group TACACS-1
aaa accounting system default
 group TACACS-1
aaa session-id common
memory-size iomem 25
no ipv6 cef
no ip source-route
no ip gratuitous-arps
ip cef
ip vrf vpn-vrf
 rd 36:36
no ip bootp server
no ip domain lookup
ip domain name xxx.com
ip name-server xxx
ip name-server xxx
license udi pid CISCO2911/K9 sn xxx
license accept end user agreement
license boot module c2900 technology-package securityk9
redundancy
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 2
track 1 ip sla 1 reachability
 delay down 15 up 10
track 2 ip sla 2 reachability
 delay down 15 up 10
track 3 ip sla 3 reachability
 delay down 15 up 10
track 4 ip sla 4 reachability
 delay down 15 up 10
class-map match-any Critical-Traffic-Class
 match access-group name Critical-Traffic
 match access-group name Voice-Signaling
class-map match-any xxx-Traffic-Class
 match access-group name xxx-Traffic
 match protocol telnet
 match protocol ssh
class-map match-any BGP
 match protocol bgp
class-map match-any Voice-Media-Class
 match access-group name Voice-Media
class-map match-any Scavenger
 match protocol http url "*youtube*"
 match protocol http url "*espn*"
class-map match-any COS1
 match ip dscp ef
 match access-group name RT_Media
policy-map MARK-BGP
 class BGP
  set ip dscp cs6
policy-map AVPN-QOS-MAP
 class Voice-Media-Class
    priority percent 30
  set dscp ef
 class Critical-Traffic-Class
    bandwidth remaining percent 50
  set dscp af31
  service-policy MARK-BGP
 class xxx-Traffic-Class
    bandwidth remaining percent 15
  set dscp af21
 class Scavenger
  set ip dscp af11
 class class-default
  set ip dscp default
policy-map AVPN-SHAPING
 class class-default
    shape average 4000000
  service-policy AVPN-QOS-MAP
crypto keyring dmvpn_keyring vrf vpn-vrf
  pre-shared-key address 0.0.0.0 0.0.0.0 key xxx
crypto isakmp policy 10
 encr aes
 authentication pre-share
crypto isakmp keepalive 60
crypto ipsec transform-set AES-SHA esp-aes esp-sha-hmac
 mode transport
crypto ipsec profile DMVPN
 set transform-set AES-SHA
interface Loopback0
 ip address xxx 255.255.255.255
interface Loopback200
 description AVPN Policy Routing
interface Loopback253
 description DMVPN Policy Routing IP
interface Tunnel1
 description xx DMVPN
 ip address xxx 255.255.255.0
 no ip redirects
 ip mtu 1440
 ip nhrp authentication xx*dmvpn
 ip nhrp map multicast dynamic
 ip nhrp map multicast xxx
 ip nhrp map xxx xxx
 ip nhrp network-id 250
 ip nhrp holdtime 120
 ip nhrp nhs xxx
 ip nhrp shortcut
 ip tcp adjust-mss 1396
 qos pre-classify
 tunnel source GigabitEthernet0/1
 tunnel mode gre multipoint
 tunnel key 250
 tunnel vrf vpn-vrf
 tunnel protection ipsec profile DMVPN shared
interface Tunnel2
 description xxx DMVPN
 no ip redirects
 ip mtu 1440
 ip nhrp map xxx xxx
 ip nhrp network-id 251
 ip nhrp nhs 10.100.251.1
 ip nhrp shortcut
 qos pre-classify
 tunnel key 251
 tunnel vrf vpn-vrf
 ip flow egress
 ip policy route-map POLICY-ROUTING
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description ** Internet Windstream 50M  **
 bandwidth 50000
 ip vrf forwarding vpn-vrf
 ip address xxx 255.255.255.252
 ip access-group internet-in in
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 duplex auto
 speed auto
 no mop enabled
interface GigabitEthernet0/2
 no ip address
 duplex full
 speed 100
 max-reserved-bandwidth 100
interface GigabitEthernet0/2.947
 description ** AT&T AVPN 4M **
 bandwidth 4000
 encapsulation dot1Q 947
 service-policy output AVPN-SHAPING
router eigrp 100
 distribute-list route-map EIGRP->DMVPN out Tunnel1
 distribute-list route-map EIGRP->DMVPN out Tunnel2
 network xxx 0.0.0.0
 network xxx 0.0.0.0
 network xxx 0.0.0.0
 network xxx 0.0.0.0
 network xxx
 network xxx
 network xxx
 network xxx
 redistribute eigrp 1 metric 100 10 255 1 1500
 passive-interface default
 no passive-interface Tunnel1
 no passive-interface Tunnel2
 eigrp router-id xxx
router eigrp 1
 network xxx 0.0.0.0
 no passive-interface GigabitEthernet0/0
router bgp 65036
 bgp router-id 10.0.36.1
 bgp log-neighbor-changes
 neighbor xxx remote-as 13979
 neighbor xxx description AT&T AVPN
 address-family ipv4
  no synchronization
  network xxx mask 255.255.255.255
  network xxx
  network xxx
  network xxx
  network xxx
  neighbor xxx activate
  neighbor xxx soft-reconfiguration inbound
  neighbor xxx route-map AVPN-IN-RM in
  neighbor xxx route-map AVPN-OUT-RM out
  no auto-summary
 exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
ip flow-top-talkers
 top 20
 sort-by bytes
ip route vrf vpn-vrf 0.0.0.0 0.0.0.0 xxx
ip access-list extended Critical-Traffic
 remark >>Critical Traffic<<
 permit ip any xxx 0.0.0.255
ip access-list extended xx-Traffic
 permit ip any xxx 0.255.255.255
 permit ip any xxx 0.0.255.255
ip access-list extended TO-DMVPN-REMOTES
 permit ip xxx 0.0.1.255 192.168.0.0 0.0.255.255
 permit ip xxx0.0.1.255 192.168.0.0 0.0.255.255
ip access-list extended Voice-Media
 remark >> Avaya RTP Traffic <<
 permit udp any range 2048 5999 any range 2048 5999
 remark >> IPT RTP Traffic <<
 permit udp any range 16384 32767 any range 16384 32767
ip access-list extended Voice-Signaling
 remark >> permit Avaya & H.323 <<
 permit tcp any eq 1720 any
 permit tcp any any eq 1720
 permit tcp any eq 1719 any
 permit tcp any any eq 1719
ip access-list extended internet-in
 permit icmp host xxx any echo
 permit gre any any
 permit esp any any
 permit udp any any eq isakmp
 permit udp any any eq non500-isakmp
 permit tcp host xxx any eq 22
 deny   ip any any
ip prefix-list AVPN-IN seq 5 permit xxx le 32
ip prefix-list AVPN-IN seq 10 permit xxx
ip prefix-list AVPN-IN seq 15 permit xxx
ip prefix-list AVPN-IN seq 20 permit xxx
ip prefix-list AVPN-IN seq 25 permit xxx
ip prefix-list AVPN-IN seq 30 permit xxx
ip prefix-list AVPN-OUT seq 5 permit xxx
ip prefix-list AVPN-OUT seq 10 permit xxx
ip prefix-list AVPN-OUT seq 15 permit xxx
ip prefix-list AVPN-OUT seq 20 permit xxx
ip prefix-list AVPN-OUT seq 25 permit xxx
ip prefix-list AVPN-OUT seq 30 permit xxx
ip prefix-list DEFAULT-ROUTE seq 5 permit 0.0.0.0/0
ip prefix-list Local-Nets seq 5 permit xxx
ip prefix-list Local-Nets seq 10 permit xxx
ip prefix-list Local-Nets seq 15 permit xxx
ip prefix-list Local-Nets seq 20 permit xxx
ip prefix-list Local-Nets->DMVPN seq 5 permit xxx
ip prefix-list Local-Nets->DMVPN seq 10 permit xxx
ip prefix-list Local-Nets->DMVPN seq 15 permit xxx
ip prefix-list Local-Nets->DMVPN seq 20 permit xxx
ip prefix-list Local-Nets->DMVPN seq 25 permit xxx
ip prefix-list Local-Nets->DMVPN seq 30 permit xxx
ip sla 1
 icmp-echo xxx source-interface Loopback200
 threshold 100
 frequency 5
ip sla schedule 1 life forever start-time now
ip sla 2
 icmp-echo 1.1.253.1 source-interface Loopback253
 threshold 100
 frequency 5
ip sla schedule 2 life forever start-time now
ip sla 3
 icmp-echo 1.1.253.2 source-interface Loopback253
 threshold 100
 frequency 5
ip sla schedule 3 life forever start-time now
ip sla 4
 icmp-echo 172.16.200.2 source-interface Loopback200
 threshold 100
 frequency 5
ip sla schedule 4 life forever start-time now
logging trap warnings
logging origin-id hostname
logging source-interface Loopback0
logging xxx
logging xxx
access-list 10 permit xxx
route-map AVPN-IN-RM deny 10
 match ip address prefix-list DEFAULT-ROUTE
route-map AVPN-IN-RM permit 20
 match ip address prefix-list AVPN-IN
route-map EIGRP->DMVPN permit 10
 match ip address prefix-list Local-Nets->DMVPN
route-map AVPN-OUT-RM permit 10
 match ip address prefix-list AVPN-OUT
route-map deny-all deny 10
route-map POLICY-ROUTING deny 5
 match ip address TO-DMVPN-REMOTES
route-map POLICY-ROUTING permit 10
 match ip address Critical-Traffic
 set ip next-hop verify-availability xxx track 1
 set ip next-hop verify-availability xxx 2 track 2
 set ip next-hop verify-availability xxx 3 track 4
route-map POLICY-ROUTING permit 20
 match ip address xxx-Traffic
 set ip next-hop verify-availability xxx track 2
 set ip next-hop verify-availability xxx track 3
route-map POLICY-ROUTING permit 30
 set ip next-hop verify-availability xxx 1 track 3
snmp-server community xxx RW
snmp-server community vector RO
snmp-server trap link ietf
snmp-server location xxx
snmp-server contact xxx IM
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps envmon
snmp-server enable traps bgp
snmp-server enable traps config
snmp-server enable traps entity
snmp-server enable traps frame-relay multilink bundle-mismatch
snmp-server enable traps frame-relay subif
snmp-server enable traps hsrp
snmp-server enable traps ipmulticast
snmp-server enable traps msdp
snmp-server enable traps rsvp
snmp-server enable traps syslog
snmp-server enable traps ipsla
snmp-server host xxx vector
control-plane
banner login ^C
******************* WARNING ********************
* You have accessed a private computer system. *
* Unauthorized access or use of this system is *
*   strictly prohibited and may be subject to  *
*        criminal and/or civil penalties.      *
* Violators will be prosecuted to the fullest  *
*             extent of the law.               *
^C
line con 0
line aux 0
line vty 0 4
 session-timeout 15
 exec-timeout 15 0
 privilege level 15
 password 7 xxx
 transport preferred telnet
 transport input telnet ssh
 transport output telnet ssh
line vty 5 15
 session-timeout 15
 exec-timeout 15 0
 privilege level 15
 password 7 xxx
scheduler allocate 20000 1000
end
