Bandwidth's unit for interface and policy-map
zillah2004
The unit for bandwidth is kilobits/sec
When I checked that for policy-map it is in kilobits/sec, but when I checked the serial interface it was not,,,any hint about this ?
Router(config-pmap-c)#bandwidth ?
<8-2000000> Kilo Bits per second
percent % of Available Bandwidth
Router(config-pmap-c)#exit
Router(config-pmap)#exit
Router(config)#
Router(config)#interface serial 0/0
Router(config-if)#bandwidth ?
<1-10000000> Bandwidth in kilobits
pkhatri
Level 11
Level 11
The two bandwidth values you are looking at serve slightly different functions. The bandwidth statement used in a policy-map enables CBWFQ and is specified in kbps. The bandwidth statement configured under the interface indicates the bandwidth associated with that interface for the purpose of QoS, OSPF costs etc. This second bandwidth is also in units of kbps, even though it says 'kilobits'.
Hope that helps - pls rate posts that help.
Paresh
