Bandwidth Shaping on DMVPN
biggy5252
Hello All,
I need assistance in shaping bandwidth over DMVPN. I tried to configure some QOS policy but it doesnt detect properly.
Here are my Ranges :
DMVPN Tunnel = 192.168.100.0/24
Inside Network Range = 10.10.10.0/24
Remote Server accessed over DMVPN = 192.168.0.200
This is how its connected; from my Branch to HQ.
User ----> Switch -----> Router -----> WAN/DMVPN -------------DMVPN/WAN ------> Router --------> Server
Default gateway is the router using SVI 10.10.10.1.
I have 1 Mbps WAN link which is to be divided with 512 used for internet and 512 used for accesing the server over DMVPN.
I did the following , but i dont see any hits on the access list or the policy-map.
class-map match-all SAP
match access-group name SAP
class-map match-all ANY
match access-group name ANY
policy-map SAP
class SAP
  priority 512
class ANY
  shape average 512000
ip access-list extended SAP
permit ip any host 192.168.0.209
permit ip any 192.168.100.0 0.0.0.255
ip access-list extended ANY
permit ip any any
interface vlan 3
service-policy output SAP
Please assist how i can achieve what i need to achieve.
before continuing with the traditional QoS-approach, are you aware of the per-tunnel-QoS for DMVP?
http://www.cisco.com/en/US/docs/ios-xml/ios/sec_conn_dmvpn/configuration/15-mt/sec-conn-dmvpn-per-tunnel-qos.html
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
I was under the impression that the DMVPN per tunnel base Qos was only when all traffic is passing the tunnel and we do a Qos for the traffic within the tunnel.
im trying to allocate bandwidth before it leaves the tunnel or the wan interface....
ill read through the link you sent in the meantime!
