Bandwidth testing
luke.bozeman
Community Member
I just implemented a new 2821 router to replace an older 3640 series router. I copied the config exactly, however, we are not getting the same 'speed' across our frame for applications. Is there a way to test the bandwidth between my two routers for my frame connection? Without purchasing any 3rd party tools?
spremkumar
Level 11
Level 11
Hi Luke
The best way would be doing a download/upload test from these locations so as to check out whether you are able to peak up to the link capacity which is connected between your locations..
regds
