Bandwidth Utilization
venvijlav123
I want to measure the bandwidth utilization per interface basis,what is the command appart from the " sh interface " is there any
other tool....gve me a simple method to find the link utilization.
Please guide me.
Ravi
Edison Ortiz
You haven't mentioned what type of hardware you have.
If you have Cat 6500, there is netflow
If you have Cat 4500, there is an option to purchase a Netflow card and gather the same info.
If you have Cat 3xxx, then you need CiscoWorks or a 3rd party NMS agent to collect information via SNMP.
Edison
tprendergast
Level 3
Level 3
In my opinion, the best tool for this is something like cacti. It uses rrdtool to graph snmp interface statistics that you poll each switch/device for. I use cacti for every network I work on.
Check it out at http://cacti.net/
I hope that helps, rate if it does.
