Bandwidth
sanuchakkalayil
Hai,
We ve a 10 mb internet line.But we want to allot a 5mb for a particular IP.We r using 3845 router.How can we configure this using traffic shpe command and how to know 5 mb is getting or not?pls help
Edison Ortiz
You may want to read this document
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hqos_c/part20/ch05/index.htm
It contains all the information you need.
HTH,
ohassairi
Level 5
Level 5
may be you can use : bandwidth reservation or GTS
there are 2 examples here:http://hassairi.50megs.com/#bwres
to be sure the user is getting the bandwidh install on his computer a bandwidth monitoring tool like netpeeker...
gaurav_thapar79
Hi, you can not segregate te traffic on per application basis on router. Its possible to limit the traffic generated by spefic IP address used in LAN towards WAN bandwidth. The ACL can be created for single IP address and rate-limit can be defined in policy-map. This policy mao would then control the up/down traffic for single/specific set of IP addresses.
Please try and share your feedback
Hai
Actually our bandwidth upgraded from 10 Mb to 30 Mb.The cable from MUX is directly connected to our 3845 router Gigabyte interface.Is there any setting in interface to receive 30 Mb?
This is the configuration .I want to allott 20Mb for tht paricular IP.Is it correct?
traffic-shape group 105 20000000 20000000 20000000 1000
traffic-shape group 106 20000000 20000000 20000000 1000
access-list 105 permit ip host 10.10.10.22any
access-list 106 permit ip any host 10.10.10.22
