Bandwith webpage limitation
opnineopnine
Hi all,
I would like to know how can I limit the bandwidth to specific web pages, (Facebook, YouTube). With my Cisco router 2800.
Thanks.
5 Replies 5
If you use nbar then you will achieve what you want. You must then match the traffic you want with policy map and limit the available bandwidth.
using nbar and class map http you will limit all web traffic not specific web pages.
I think you are wrong:
http://networklessons.com/quality-of-service/block-website-with-nbar-on-cisco-router/
http://blog.zakir.net/index.php?/archives/5-Blocking-sites-using-NBAR.html
http://www.cisco.com/c/en/us/products/collateral/ios-nx-os-software/network-based-application-recognition-nbar/qa_c67-646888.html
yes, you are correct
using
R1(config)#class-map match-any BLOCKED
R1(config-cmap)#match protocol http host "*youtube.com*"
R1(config)#policy-map DROP
R1(config-pmap)#class BLOCKED
R1(config-pmap-c)#drop
R1(config-pmap-c)#exit
will block web pages youtube.com
Can someone post an example?
thanks
