Basic Firewall Configuration With DMZ, help!
richarddowna
Hello
I am trying to set up my Cisco 520 router with a firewall that will:
DMZ
- Allow port 80 traffic to the vlan 20
- Block all other incomming ports to vlan 20 (unless initalised from inside)
- Allow all outgoing ports on vlan 20
- Block all access from vlan 20 to vlan 10 (unless initalised from vlan 10)
General Network
- Block all incomming ports to vlan 10 (unless initalised from inside)
- Allow all outgoing ports on vlan 10
- Allow all access from vlan 10 to vlan 20
I have read some articles on this, and i need a bit of help understanding some things.
Ill post my understanding so far with some questions.
Any help and or corrections would be greatly appreciated!
First, configure basic firewall with no port 80 access
Router(config)# access-list 103 deny ip any any
Router(config)# access-list 103 permit host 200.1.1.1 eq isakmp any (1. Why 200.1.1.1? what does this command do?)
Inspect Rules (2. Are all these necessary? are there more than this?)
Router(config)# ip inspect name firewall tcp
Router(config)# ip inspect name firewall rtsp
Router(config)# ip inspect name firewall h323
Router(config)# ip inspect name firewall netshow
Router(config)# ip inspect name firewall ftp
Router(config)# ip inspect name firewall sqlnet
Apply Access List to Interface
Router(config)# interface vlan 10
Router(config-if)# ip inspect firewall in
Router(config-if)# exit
Router(config)# interface vlan 20
Router(config)# interface (3. ATM? ATM.0? Dialer0?) - Note I am using ADSL over PPPoA with ATM ATM.0 and Dialer0 interfaces
Router(config-if)# ip access-group 103 in
Configure VLAN10 to VLAN20 rules
int vlan 10
desc General Network
ip access-group 100 in
ip nat inside
int vlan 20
desc DMZ
ip access-group 101 in
ip nat inside
ip nat inside source list 1 interface Dialer0 overload
access-list 1 remark Permited Subnets to go out to the Internet
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 100 remark Restricted Inside network Access
access-list 100 permit tcp 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255
access-list 100 permit udp 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255 eq 53
access-list 100 deny ip 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255
access-list 100 permit ip 192.168.10.0 0.0.0.255 any
access-list 101 remark Restricted DMZ network Access
access-list 101 permit tcp 192.168.20.0 0.0.0.255 192.168.10.0 0.0.0.255 established
access-list 101 permit udp 192.168.20.0 0.0.0.255 eq 53 192.168.10.0 0.0.0.255
access-list 101 deny ip 192.168.20.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 101 permit ip 192.168.20.0 0.0.0.255 any
(4. Do the above VLAN10 and VLAN20 rules seem correct?)
(5. How do i now forward incomming HTTP port 80 traffic to 192.168.20.0?)
(6. Even better, can i forward the HTTP traffic from a different mapped port other than 80? And can this be forwarded to a specific IP address eg. 192.168.20.254?)
Thanks in advance for any help
Richard
Can you try this one: access-list 100 permit tcp 192.168.10.0 0.0.0.255 host 192.168.20.254 eq 22
Regards.
Alain.
35 Replies 35
cadet alain
Your second line will never get hit as you are denying everything in your first line so you should get rid of this line 1 and leave the implicit deny all
There is also an error in line 2: it should say access-list 103 permit udp host 200.1.1.1 eq isakmp any
It will permit initiation of phase 1 from the other end  router in IPSec VPN creation, that's why you have a public ip address which should be the WAN ip address of the other router.
Yes ther are a lot more but I would inspect udp also
I would apply on Dialer0 but I'm not 100% sure.
as you're using CBAC there is no need for the established keyword anymore
access-list 1 permit 192.168.10.0 0.0.0.255 shouldn't it be 192.168.20.0 ?
you must use static pat: ip nat inside source static tcp 192.168.20.254 80 interface Dialer0 80
This is only a 1-1 relationship.
Yes of course: ip nat inside source static tcp 192.168.20.254 80 interface Dialer0 8080 or ip nat inside source static tcp 192.168.20.254 8080 interface Dialer0 80
Regards.
Alain.
Thankyou Alain,
Here a the revised commands,
Please let me know if ive made any errors, cheers!!
Router(config)# ip inspect name firewall udp
Router(config-if)# description General Network
Router(config-if)# ip access-group 100 in
Router(config-if)# ip nat inside
Router(config-if)# description DMZ
Router(config-if)# ip access-group 101 in
Router(config)# interface Dialer 0
Router(config)# ip nat inside source list 1 interface Dialer0 overload
Router(config)# access-list 1 remark Permited Subnets to go out to the Internet
Router(config)# access-list 1 permit 192.168.10.0 0.0.0.255
Router(config)# access-list 1 permit 192.168.20.0 0.0.0.255
Router(config)# access-list 100 remark Restricted Inside network Access
Router(config)# access-list 100 permit tcp 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255
Router(config)# access-list 100 permit udp 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255 eq 53
Router(config)# access-list 100 deny ip 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255
Router(config)# access-list 100 permit ip 192.168.10.0 0.0.0.255 any
Router(config)# access-list 101 remark Restricted DMZ network Access
Router(config)# access-list 101 permit tcp 192.168.20.0 0.0.0.255 192.168.10.0 0.0.0.255 established
Router(config)# access-list 101 permit udp 192.168.20.0 0.0.0.255 eq 53 192.168.10.0 0.0.0.255
Router(config)# access-list 101 deny ip 192.168.20.0 0.0.0.255 192.168.10.0 0.0.0.255
Router(config)# access-list 101 permit ip 192.168.20.0 0.0.0.255 any
Router(config)# ip nat inside source static tcp 192.168.20.254 80 interface Dialer0 8080
Hi Richard,
This is what I done my 806 router as Basic Firewall with DMZ and hope this will help you.
DMZ interface
interface Ethernet0
ip address 10.10.10.1 255.255.255.0
ip nat inside
ISP interface
interface Ethernet1
ip address 216.93.82.8 255.255.255.240
ip nat outside
Default route to ISP's gateway
ip route 0.0.0.0 0.0.0.0 216.93.82.1
Static route to inside filter router (internal LAN traffic)
ip route 172.17.0.0 255.255.0.0 10.10.10.2
Allow traffic from internal LAN out
access-list 1 permit 172.17.0.0 0.0.255.255
ip nat inside source list 1 interface Ethernet1 overload
Send incoming SMTP mail traffic Solaris box
ip nat inside source static tcp 10.10.10.5 21 216.93.82.8 25 extendable
Send incoming Web traffic to Debian box
ip nat inside source static tcp 10.10.10.3 80 216.93.82.8 80 extendable
Please rate the all helpfull posts.
Naidu.
Hello thanks for that,
I have tried the configuration i posted above and well. Its not working how i intended. And im really struggling to see why
I need these rules:
DMZ
General Network
But with the commands i posted two posts above,
vlan 10 cannot ping vlan 20
vlan 20 cannot ping vlan 10
I would permit DHCP traffic in ACL 103: permit udpany any eq bootpc otherwise you'll have no ip address from your ISP unless you have a static IP.
I would add ip inspect log drop-pkt in global config and ip inspect firewall icmp
You can get rid of established  keyword in ACL 101
Then I would do  testing of communication between vlans and then with internet( with pings)
Regards.
Alain.
Hi Richard,
OK, I am assuming Vlan 10 Ip range is 192.168.10.0 and Vlan 20 range is 192.168.20.0
And follow the below config may help you.
Router(config)# access-list 101 deny tcp any 192.168.20.0 0.0.0.255
Router(config)# access-list 101 deny udp any 192.168.20.0 0.0.0.255
Router(config)# access-list 101 permit ip any any eq 80
Router(config)# access-list 101 permit tcp 192.168.20.0 0.0.0.255 any
Router(config)# access-list 101 permit udp 192.168.20.0 0.0.0.255 any
Router(config)# access-list 100 deny tcp any 192.168.20.0 0.0.0.255
Router(config)# access-list 100 deny udp any 192.168.20.0 0.0.0.255
Router(config)# access-list 100 permit ip any 192.168.20.0 0.0.0.255
Router(config)# access-list 100 permit tcp 192.168.10.0 0.0.0.255 any
Router(config)# access-list 100 permit udp 192.168.10.0 0.0.0.255 any
Hope the above will help you.
Naidu.
Hello Naidu,
Im a bit confused, wont this line deny access from 192.168.10.0 to 192.168.20.0?
I am trying to allow all trafic initiated by 192.168.10.0 towards 192.168.20.0
and deny all traffic initiated by 192.168.20.0 towards 192.168.10.0
Since vlan 20 is my DMZ, i do not want it to be able to access vlan 10, but i do want vlan 10 to be able to access vlan 20.
Or is this command working how it should?
Hi Richard,
I just denied tcp & udp as you want block all outgoing ports on vlan 20
The following rule will do the needy...Router(config)# access-list 100 permit ip any 192.168.20.0 0.0.0.255
Naidu.
Thankyou Naidu,
I will give those commands a try,
Before I do, I want to make sure ive got the commands correct to open two ports on the router and forward them to 192.168.20.254
I want port 22 open translated to port 54321 (external port) and pointing to 192.168.20.254
I want port 80 open and pointing to 192.168.20.254
This is what I have, I tried these previously and ran an external port scan, unfortunatly it showed these ports still blocked.
Router(config)# access-list 103 permit tcp any host 192.168.20.254 eq 80
Router(config)# access-list 103 permit tcp any host 192.168.20.254 eq 54321
Router(config)# ip nat inside source static tcp 192.168.20.254 22 interface Dialer0 54321
Thankyou for the all the help. Much appreciated
Cheers
It can't  work you must use the Public IP not the private one.
To prove it, just do a show access-list and you won't see hits for these 2 lines
Regards.
Alain.
Router#sh access-lists
Extended IP access list 103
    10 permit tcp any host 192.168.20.254 eq www
This is showing up!
I didn't say it wouldn't be showing up, I said you would have no matches for these lines but only matches for the implicit deny. look at the right of the ACL line.
Regards.
Alain.
So should i open the port on the Dialer0 interface (my external IP)
Then use nat to forward the port to the server 192.168.20.254?
If so, how would i do this? Thanks
Yes but as you are using a public IP given with DHCP from ISP, you'll have to permit for any ip address.
