Basic Firewall Configuration With DMZ, help!
richarddowna
Hello
I am trying to set up my Cisco 520 router with a firewall that will:
DMZ
- Allow port 80 traffic to the vlan 20
- Block all other incomming ports to vlan 20 (unless initalised from inside)
- Allow all outgoing ports on vlan 20
- Block all access from vlan 20 to vlan 10 (unless initalised from vlan 10)
General Network
- Block all incomming ports to vlan 10 (unless initalised from inside)
- Allow all outgoing ports on vlan 10
- Allow all access from vlan 10 to vlan 20
I have read some articles on this, and i need a bit of help understanding some things.
Ill post my understanding so far with some questions.
Any help and or corrections would be greatly appreciated!
First, configure basic firewall with no port 80 access
Router(config)# access-list 103 deny ip any any
Router(config)# access-list 103 permit host 200.1.1.1 eq isakmp any (1. Why 200.1.1.1? what does this command do?)
Inspect Rules (2. Are all these necessary? are there more than this?)
Router(config)# ip inspect name firewall tcp
Router(config)# ip inspect name firewall rtsp
Router(config)# ip inspect name firewall h323
Router(config)# ip inspect name firewall netshow
Router(config)# ip inspect name firewall ftp
Router(config)# ip inspect name firewall sqlnet
Apply Access List to Interface
Router(config)# interface vlan 10
Router(config-if)# ip inspect firewall in
Router(config-if)# exit
Router(config)# interface vlan 20
Router(config)# interface (3. ATM? ATM.0? Dialer0?) - Note I am using ADSL over PPPoA with ATM ATM.0 and Dialer0 interfaces
Router(config-if)# ip access-group 103 in
Configure VLAN10 to VLAN20 rules
int vlan 10
desc General Network
ip access-group 100 in
ip nat inside
int vlan 20
desc DMZ
ip access-group 101 in
ip nat inside
ip nat inside source list 1 interface Dialer0 overload
access-list 1 remark Permited Subnets to go out to the Internet
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 100 remark Restricted Inside network Access
access-list 100 permit tcp 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255
access-list 100 permit udp 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255 eq 53
access-list 100 deny ip 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255
access-list 100 permit ip 192.168.10.0 0.0.0.255 any
access-list 101 remark Restricted DMZ network Access
access-list 101 permit tcp 192.168.20.0 0.0.0.255 192.168.10.0 0.0.0.255 established
access-list 101 permit udp 192.168.20.0 0.0.0.255 eq 53 192.168.10.0 0.0.0.255
access-list 101 deny ip 192.168.20.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 101 permit ip 192.168.20.0 0.0.0.255 any
(4. Do the above VLAN10 and VLAN20 rules seem correct?)
(5. How do i now forward incomming HTTP port 80 traffic to 192.168.20.0?)
(6. Even better, can i forward the HTTP traffic from a different mapped port other than 80? And can this be forwarded to a specific IP address eg. 192.168.20.254?)
Thanks in advance for any help
Richard
35 Replies 35
Excellent! That worked!
Thank you Alain for your help
and Thank you Naidu for your access lists, these worked perfectly.
I just have one last access list tweak!
I need 192.168.10.0 to be able to ssh via port 22 into 192.168.20.254
currently it says:
Connection refused.
Hi Richard,
Try with the below one should do that...
Router(config)# access-list 100 permit ip 192.168.10.0 0.0.0.255 192.168.20.254 0.0.0.255 eq 22
Please rate the all helpfull posts.
Naidu.
I am getting this error:
% Invalid input detected at '^' marker.
at 'eq'
thanks
replace ip by tcp like this:  access-list 100 permit tcp 192.168.10.0 0.0.0.255 192.168.20.254 0.0.0.255 eq 22
Regards.
Alain.
Hi Richard,
Router(config)# access-list 100 permit tcp 192.168.10.0 0.0.0.255 eq 22 host host 192.168.20.254 eq 22
Naidu.
Neither commands worked!
The last one tired to lookup the dns for a hostname hehe!
I tried
but still connection refused. do i need to try on port 54321 instead since i have mapped 22 to it?
Can you try this one: access-list 100 permit tcp 192.168.10.0 0.0.0.255 host 192.168.20.254 eq 22
Regards.
Alain.
just to confirm this is
from 192.168.10.0 network
to 192.168.20.254 server
via 22
thanks again
Can you add the log keyword at the end of the ACL and try again. make sure logging is enabled on console with the show login command.
if there is a log then the ACL is fine and there must be something else, can you post the ssh command you are doing  as well as netstat  command on the server( if it's a linux do netstat | grep ssh)
Regards.
Alain.
Hi Alain,
Nothing shows up on the router with the logging.
Nothing shows up from the netstat | grep ssh
I am using mac terminal to log into the linux server via this command:
ssh user@192.168.20.254
ssh connect to host 192.168.20.254 port 22: Connection refused
I CAN however log in to ssh from the outside of the network. For example from my cell phone while not on the local network.
Also, if I connect the server back up to the old network with the old router, it allows ssh! So i dont think the server is the issue
Cheers
How are you connected on the router? if you shut/noshut an interface are you seeing a log message
Regards.
Alain.
Hi Richard,
Router(config)# access-list 100 permit ip 192.168.10.0 0.0.0.255 host 192.168.20.254
And try ssh...
Naidu.
Hi Naidu,
This did not work, still connection refused.
Interesting it happens even with the server unplugged from the network.
I will try your suggestion next Alain, and post results.
Hi Richard,
How can you connect to a service if the server is not on the network? So that is normal behaviour.
Regards.
Alain.
Hi Richard,
Please connect the server in Network.
Once you connect try to ping the server from the allowed network, if it is able to ping then the telnet on port 22 should work.
Good luck...
Naidu.
