Basic Improvements on Network
Hello all,
I am new in a networking job and i have noticed some misconfigurations.
For example i checked the time on L3 switch and i noticed that is completely wrong.
Also, on some interfaces i saw that the below configuration which it doesn't seem to be correct
switchport access vlan 80
switchport trunk native vlan 80
switchport trunk allowed vlan 80,81
switchport mode trunk
switchport voice vlan 81
spanning-tree portfast
Can you please suggest me some other basic/initial improvements that i have to check and fix them?
Is there something like a "guide" for such cases in order to have it a reference?
Thank you in advance,
Giannis
2 Accepted Solutions
Seb Rupik
Hi there,
Certainly having your switches synced with the same NTP would be a good idea.
Regarding the interface config you have shared, it is perfectly valid. The switchport access xx is redundant config whilst the switchport mode is trunk. It will not affect its operation.
If you want a good guide to get stuck into, take a look at this. No doubt you will find plenty to implement! :
https://www.cisco.com/c/en/us/support/docs/ip/access-lists/13608-21.html
cheers,
Seb.
Hi anousakisioannis,
I would suggest Cisco best practices documents for improvements regarding your network. Security and basic configuration wise the Cisco Guide to Harden Cisco IOS Devices is a good start:
https://www.cisco.com/c/en/us/support/docs/ip/access-lists/13608-21.html#anc47
HTH,
6 Replies 6
Seb Rupik
Hi there,
cheers,
Seb.
Hello Seb,
Thank you for your fast response! It seems a good document to start.
Regarding the interface configuration, this port is working as a trunk. right?
And when you say redundant, do you mean that if i disable trunking will be access?
Giannis
Yes, the port is working as a trunk. Use the following command to confirm:
sh int <switchport_name> switchport
...this will show you the operational mode. You can only have one switchport mode listed at any one time; they will replace each other in the config.
It is redundant as it serves no purpose whilst the operational mode of the switchport is not access.
cheers,
Seb.
Clear!!!!!
Thank you very much!
Giannis
HTH,
Thank you Konstantinos!
