Basic Router Configuration - not outside access
joewalvoxbright
              Working on setting up a basic router.  I have looked at may posts this one
https://supportforums.cisco.com/message/4111294#4111294 seems to be the closest but do not seem to understand all need to get it working.
From router# prompt -  i can ping 8.8.8.8 and I can ping computer (192.168.25.5) on the inside.  But cannot ping from lan (192.168.25.5) to internet.
Router#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 24/27/36 ms
Router#ping 192.168.25.5
Sending 5, 100-byte ICMP Echos to 192.168.25.5, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
joes-Mac-mini:~ joewallace$ ping 192.168.25.1
PING 192.168.25.1 (192.168.25.1): 56 data bytes
64 bytes from 192.168.25.1: icmp_seq=0 ttl=255 time=0.511 ms
64 bytes from 192.168.25.1: icmp_seq=1 ttl=255 time=0.725 ms
64 bytes from 192.168.25.1: icmp_seq=2 ttl=255 time=0.529 ms
^C
--- 192.168.25.1 ping statistics ---
3 packets transmitted, 3 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 0.511/0.588/0.725/0.097 ms
joes-Mac-mini:~ joewallace$ ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8): 56 data bytes
Request timeout for icmp_seq 0
Request timeout for icmp_seq 1
Router#ping 8.8.8.8
Current configuration : 1217 bytes
! Last configuration change at 19:04:43 UTC Mon Dec 9 2013
version 15.2
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
license udi pid CISCO1921/K9 sn FGL172625ST
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description Outside World
ip address 192.168.20.18 255.255.255.0
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description Internal LAN
ip address 192.168.25.1 255.255.255.0
ip nat inside
duplex auto
speed auto
ip default-gateway 192.168.25.1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.20.1
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
John Blakley
Joe,
You need to configure nat for your subnet on the lan. You're missing a couple of lines it seems:
access-list 100 permit ip 192.168.25.0 0.0.0.255 any
ip nat inside source list 100 interface g0/0 overload
And you can remove "ip default-gateway 192.168.25.1". It's only used when routing is disabled, and it's not going to be in your case.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
John Blakley
Joe,
HTH,
John
Here is the working version of the config.  When I was surfing the forum really wished to see the working version.
Current configuration : 1306 bytes
! Last configuration change at 19:39:26 UTC Mon Dec 9 2013
version 15.2
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
no ip address
shutdown
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
no ip http server
ip nat inside source list 100 interface GigabitEthernet0/0 overload
control-plane
line con 0
line aux 0
line 2
no exec
transport input all
stopbits 1
line vty 0 4
login
transport input all
end
