Basic T1 Configuration for Cisco Router to Juniper Router
milkboy33
Hi All!
   I've never done this before. Hope someone can help.
   What is the very basic config example that we will need to do on our Cisco router to get to communicate to a Juniper router (T1 connection).
Thanks all!
Tom
tony.henry_2
Tom,
I'd start with the link protocol and choose PPP between them both. You'll then need to make some decisions regarding the routing protocol, OSPF or BGP; would be obvious selections.
in the serial interface
int serX
encapsulation ppp
ip address X.X.X.X 255.255.255.252
no shutdown
router ospf 1
network X.X.X.X 0.0.0.3 area 0
I don't think that the Juniper config will be much different.
I hope that gets you started.
Tony
