Best course on Cisco routing
betens
Title, looking for a detailed course in Cisco routing.
Any suggestions?
I'm not looking to do this for a cert, I'm already certified, it's more of a personal growth thing, so it doesn't have to align with anything in particular.
Thanks!
Jon Marshall
Depends on how you learn but for me I would just buy the CCIE routing book and get a lab setup, probably virtual rather than using physical equipment.
If you prefer videos then hopefully others can suggest as I don't get along with them at all.
Jon
 If you are not looking into certs, then the dynamic can be a lot different and I recommend you to get familiar with simulators(PacketTracer, GNS3, Eve,etc). And then, from internet videos , materials and with the help of this community you can improve really fast.
I mention simulator cause there´s no better way to improve then getting your hands durty.  You  actually learn when you do it wrong and then make it right after.
All the trainning you are going to find, will be somehow focused on some Cert.
Martin L
I understand new Cert has extra stuff like Programming and automation nad SD-WAN.  So I would say the course is no good.  there is no single book but several multiple books might do a trick.  Go to ciscopress book store and look for following:
For all protocols and especially EIGRP, I would start with Routing TCP/IP by Dolye.
Also look at CCIE RS v5.0 cert guide books , not for Enterprise (2 set books for previous CCIE version or last one for RS track with Narbik and Paluch as authors)
for BGP I would get Internet routing architectures in addition to mentioned above book set
OSPF - best are books by John Moy, OSPF Anatomy of an Internet Routing Protocol - this one not from cisco press.
Regards, ML
**Please Rate All Helpful Responses **
OK You want advance course for OSPF EIGRP BGP
in google
just write
ciscolive OSPF
the browser will give you many PPT about OSPF download it and enjoy reading.
ciscolive for me is best course  ever
