Best IP Address Config for Router and PIX
anthonym
Our current network setup is:
Internet--->router--->pix506e->local network
The router in use is ISP provided, and very simple, it has a single public IP x.x.x.185.
Outside on the PIX is set to x.x.x.188 and inside is 192.168.93.1.
The internal subnet is 192.168.93.0/24
We have acquired a 1721 router, which has two interfaces.
I have set Dialer0 to x.x.x.188, and FastEthernet0 to 192.168.93.10. In this case I can ping external IP addresses from the router, but not the PIX.
How do I set this up such that the pix can be accessed at x.x.x.188, through the 1721?
6 Replies 6
zhiqiang.yan
you need to set NAT in your router, because the ip of f0 is your internal address, internet doesn't it.
With NAT set in the 1721 will the PIX be accessable as x.x.x.188?
I would like initially to replicate the current set-up, the other public addresses will be used later for more services from the inside.
Oh, your PIX outside address is x.x.x.188, but it connects to 1721 Fa0, the ip of fa0 is 192.168.x.x?
I think you should setup a public in the fa0, or your outside address is 192.168.x.x.
if fa0 is public address, the nat/pat should be set up in PIX. I guest you did.
My confusion comes from the fact that the current router has only one IP, the public one, whereas the 1721 seems to need two.
If Fa0 is set to a public address, what happens to the address on the ADSL interface?
The current config is below:
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
hostname xxxx
boot-start-marker
boot-end-marker
logging console emergencies
enable secret 5 xx
enable password 7 xx
no aaa new-model
resource policy
clock timezone BST 1
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
no ip source-route
no ip gratuitous-arps
no ip dhcp use vrf connected
ip cef
no ip bootp server
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
hold-queue 224 in
pvc 0/38
protocol ip x.x.x.191 broadcast
dialer pool-member 1
protocol ppp dialer
interface FastEthernet0
ip address 192.168.93.10 255.255.255.0
speed auto
full-duplex
no cdp enable
interface Dialer0
ip address x.x.x.185 255.255.255.0
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname xx
ppp chap password 7 xx
!interface Dialer1
no ip address
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
dialer-list 1 protocol ip permit
no cdp run
control-plane
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
password 7 xx
login
no process cpu extended
no process cpu autoprofile hog
sntp server 192.168.93.4
end
So, I know what you have.
(1)
setup a ip 192.168.93.x/24 on the fa0 of 1721, and config pat on the router.
pix set as Transparent mode. no ip on the pix.
or (2)
set ip 192.168.1.1/30 on the fa0 of 1721.
set ip 192.168.1.2/30 on outside of pix.
ip 192.168.93.x/24 on inside
set route 192.168.93.x/24 to 192.168.1.2 on router
set route 0.0.0.0 to 192.168.1.1 on pix
set pat on router
I will try the second option this evening, as this is a production network.
Is it possible to do the first option on a PIX506E? If so, I do not know how.
I am sure I am making this sound more complicated than it is, this should be a simple task I am sure.
From the ISP I am given an IP range x.x.x.185-191 with 185 as the gateway. If I were to only use public addresses how would I set up the 1721?
i.e. Server (x.x.x.188)->1721->Internet
I should be able to work out the rest from there.
