Best way to encrypt MPLS WAN's
carl_townshend
Hi All
At the moment, we have an MPLS WAN, using encrypted GRE tunnels, manually configured.
This isn't scalable and requires lots of manual tunnel configs each time a site is added.
What is the best way forward for this, DMVPN or GETVPN?
Cheers
Filip Knezevic
They are similar solutions, but both would be better in your situation. GETVPN is essentially a DMVPN on steroids. So if your router supports GETVPN, I would suggest that road.
Captain HoOmi
Well the best benefit of getvpn is being tunellness and hence much faster. Go with Getvpn if you can.
I think this link may be helpful for you : https://micronicstraining.com/getvpn-over-dmvpn/#targetText=General%20rule%20for%20both%20is,MPLS%20VPN).
** Please rate this post or accept the solution if it helped! :) **
