04-11-2013 02:37 AM - edited 03-04-2019 07:33 PM
Hi all
I have 3 routers where I want to load balance traffic between them, these are between site A and B
They all connect to a core switch on both ends.
I want each router to be a failover of the other,
what is the best method of achieving this ? I want to use static routes from my core.
cheers
Carl
04-11-2013 06:26 AM
if possiable, please use RIP. I think this is good for you. Easy, sample~!
If you still want use static routing. Don't be forget using track for it. It can help you to failover of the other.
04-11-2013 06:39 AM
How do these sites connect to each other?
What is the handoff (layer2 or layer3) what is the medium (fiber, cat5)?
Is there a carrier providing connection between these locations?
04-11-2013 09:03 AM
The sites connect via serial, and layer 2 dedicated links, all which are managed by me.
the handoff is currently HSRP , multiple groups and we route to each router via this address.
Is there a better way of routing this ?
cheers
Carl
04-12-2013 06:50 AM
Better is a matter of opinion, but if you are looking for the best/easiest way to load-balance, then you may want to use GLBP. It inherently "round robins" load-balances to each arp request for the gateway address.
