06-30-2020 11:03 AM
Hi all
what are most people doing to tunnel layer 2 vlans over a layer 3 wan link?
can you tunnel multiple vlans using l2tp?
if so has anyone got a sample config?
what other options are there?
cheers
Carl
06-30-2020 11:21 AM
L2TPv3 (togther with IPSec) is probably your best option. Below a sample configuration on how to trunk multiple Vlans.
https://gallery.technet.microsoft.com/Cisco-Layer-2-Vlan-Trunk-8bab7961
07-01-2020 05:56 AM
Hi George
Thanks for that
Do the other options such as Eompls / VPLS done by the ISP and are more service provider technologies?
What about EVPN using BGP, is that another option? can you use it without vxlan ?
