11-10-2024 08:21 AM
We have a connection from on-premises to Azure via the ExpressRoute virtual router, with BFD enabled. The BFD interval is set to 1000ms on the on-premises side and 300ms on the Azure side. However, the BGP session is frequently resetting due to BFD being down. Can anyone suggest a solution to stabilize this link?
regards,
11-10-2024 08:50 AM
what is the Logs show on the Device, what device on-premisses (router and IOS running)
check some troubleshooting tips :
Try disabling the BFD and see is the BGP stable ? (for troubleshooting)
11-10-2024 12:01 PM
What is the min_rx and max age set to on either end?
11-10-2024 08:47 PM
as per the BFD template min-tx 1000 and min-rx 1000 multipliers 3
R1-bfd 1000ms------to-----Azure --- bfd 300ms
11-18-2024 12:49 AM
could you please confirm if high bandwidth utilization due to the BFD session will go down very often
11-18-2024 01:00 AM
Why you use mismatch interval in each side?
MHM
12-04-2024 11:19 AM
any update ?
MHM
01-27-2025 12:46 AM
Do mismatch intervals lead to any issues with the link?
01-27-2025 01:30 AM
Friend
Before I reply can I know the platform you have?
MHM
01-27-2025 11:19 AM
Hello
Suggest remove bfd and see if the peering stabilise
