BFD neighbors down
pslovinsky
Hi guys,
i have problem with BFD. BFD neighbors are permanently down. No way to bring them up.
Setup:
Two routers (TTR255 - 2911and IBR255 - 3945(HWIC FE)) are connected via one ethernet link. Routing protocol EIGRP. Routers are configured for VRF-lite using subinterfaces(VLAN 1516,1517,1518). BFD ais enabled on EIGRP adress families and also under corresponding subinterface.
I am using IOS 150-1.M7 and also try 152-2.T. I have DATA license.
Does anybody have same problem?
For more details see attached files.
Thanks, Pato
Peter Paluch
Hello Patrik,
This is an interesting issue. Please give me a day or so to emulate your config on real devices and come back with my observations. The VRF-aware BFD should be supported on IOSes starting with versions 15.0M.
I assume that the EIGRP itself is working well and adjacencies are being built as appropriate, just the BFD support does not seem to come up - am I correct here?
Best regards,
Peter
Yes, you are correct, EIGRP adjacencies are up and traffic is passing link without any troubles.
Best regards,
Patrik
Peter Paluch
Hi Pato,
I've replicated the key parts of your config on 1841 routers in my lab. I'm running Advanced IP Services, IOS version 15.1(4)M2. I can not replicate the problem, however: the BFD neighbors came up as expected, I had no issues in the whole config coming up on the first attempt.
Please see the following output of the configurations and show commands:
R1 is the "TTR255":
ip vrf ADMIS
rd 1:3
ip vrf OPS
rd 1:1
ip vrf SUP
rd 1:2
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.1516
description OPS VLAN - prepoj na IBR255 Fa0/0
bandwidth 4000
encapsulation dot1Q 1516
ip vrf forwarding OPS
ip address 172.21.101.86 255.255.255.248
no ip proxy-arp
bfd interval 200 min_rx 200 multiplier 4
interface FastEthernet0/1.1517
description SUP VLAN - prepoj na IBR255 Fa0/0
bandwidth 4000
encapsulation dot1Q 1517
ip vrf forwarding SUP
ip address 172.21.191.190 255.255.255.248
no ip proxy-arp
interface FastEthernet0/1.1518
description ADMIS VLAN - prepoj na IBR255 Fa0/0
bandwidth 4000
encapsulation dot1Q 1518
ip vrf forwarding ADMIS
ip address 172.16.160.30 255.255.255.248
no ip proxy-arp
router eigrp 1
address-family ipv4 vrf OPS autonomous-system 100
  bfd interface FastEthernet0/1.1516
  network 172.21.101.86 0.0.0.0
  network 172.21.191.226 0.0.0.0
  network 172.21.191.255 0.0.0.0
  passive-interface default
  no passive-interface FastEthernet0/1.1516
  eigrp router-id 172.21.191.255
exit-address-family
address-family ipv4 vrf SUP autonomous-system 100
  bfd interface FastEthernet0/1.1517
  network 172.21.191.190 0.0.0.0
  network 172.21.191.234 0.0.0.0
  no passive-interface FastEthernet0/1.1517
exit-address-family
address-family ipv4 vrf ADMIS autonomous-system 100
  bfd interface FastEthernet0/1.1518
  network 172.16.160.30 0.0.0.0
  network 172.21.191.242 0.0.0.0
  no passive-interface FastEthernet0/1.1518
exit-address-family
shutdown
R1#show bfd neighbors
NeighAddr                         LD/RD    RH/RS     State     Int
172.16.160.25                      1/6     Up        Up        Fa0/1.1518
172.21.101.81                      5/2     Up        Up        Fa0/1.1516
172.21.191.185                     2/4     Up        Up        Fa0/1.1517
R1#show bfd neighbors detail
Session state is UP and using echo function with 200 ms interval.
OurAddr: 172.16.160.30
Local Diag: 0, Demand mode: 0, Poll bit: 0
MinTxInt: 1000000, MinRxInt: 1000000, Multiplier: 4
Received MinRxInt: 1000000, Received Multiplier: 4
Holddown (hits): 0(0), Hello (hits): 1000(690)
Rx Count: 698, Rx Interval (ms) min/max/avg: 1/1000/873 last: 544 ms ago
Tx Count: 691, Tx Interval (ms) min/max/avg: 756/1000/883 last: 424 ms ago
Elapsed time watermarks: 0 0 (last: 0)
Registered protocols: EIGRP
Uptime: 00:10:09
Last packet: Version: 1                  - Diagnostic: 0
             State bit: Up               - Demand bit: 0
             Poll bit: 0                 - Final bit: 0
             Multiplier: 4               - Length: 24
             My Discr.: 6                - Your Discr.: 1
             Min tx interval: 1000000    - Min rx interval: 1000000
             Min Echo interval: 200000
OurAddr: 172.21.101.86
Holddown (hits): 0(0), Hello (hits): 1000(695)
Rx Count: 697, Rx Interval (ms) min/max/avg: 1/1000/875 last: 176 ms ago
Tx Count: 697, Tx Interval (ms) min/max/avg: 4/1004/874 last: 520 ms ago
Uptime: 00:10:09
             My Discr.: 2                - Your Discr.: 5
OurAddr: 172.21.191.190
Rx Count: 695, Rx Interval (ms) min/max/avg: 1/1000/877 last: 644 ms ago
Tx Count: 691, Tx Interval (ms) min/max/avg: 756/1000/882 last: 424 ms ago
Uptime: 00:10:09
             My Discr.: 4                - Your Discr.: 2
R1#
R2 is the "IBR255":
ip vrf ADMIS
rd 1:3
ip vrf OPS
rd 1:1
ip vrf SUP
rd 1:2
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1516
description OPS VLAN - prepoj na TTR255 Gi0/1
bandwidth 4000
ip address 172.21.101.81 255.255.255.248
no ip proxy-arp
interface FastEthernet0/0.1517
description SUP VLAN - prepoj na TTR255 Gi0/1
bandwidth 4000
ip address 172.21.191.185 255.255.255.248
no ip proxy-arp
interface FastEthernet0/0.1518
description ADMIS VLAN - prepoj na TTR255 Gi0/1
bandwidth 4000
ip address 172.16.160.25 255.255.255.248
no ip proxy-arp
router eigrp 1
  bfd interface FastEthernet0/0.1516
  network 172.21.101.81 0.0.0.0
  network 172.21.101.97 0.0.0.0
  network 172.21.182.226 0.0.0.0
  network 172.21.182.255 0.0.0.0
  no passive-interface FastEthernet0/0.1516
  eigrp router-id 172.21.182.255
exit-address-family
  bfd interface FastEthernet0/0.1517
  network 172.21.182.234 0.0.0.0
  network 172.21.191.185 0.0.0.0
  network 172.21.192.185 0.0.0.0
  no passive-interface FastEthernet0/0.1517
exit-address-family
  bfd interface FastEthernet0/0.1518
  network 172.16.160.9 0.0.0.0
  network 172.16.160.25 0.0.0.0
  network 172.21.182.242 0.0.0.0
  no passive-interface FastEthernet0/0.1518
exit-address-family
shutdown
R2#show bfd neighbors
172.16.160.30                      6/1     Up        Up        Fa0/0.1518
172.21.101.86                      2/5     Up        Up        Fa0/0.1516
172.21.191.190                     4/2     Up        Up        Fa0/0.1517
R2#show bfd nei details
OurAddr: 172.16.160.25
Holddown (hits): 0(0), Hello (hits): 1000(820)
Rx Count: 816, Rx Interval (ms) min/max/avg: 1/3384/882 last: 208 ms ago
Tx Count: 826, Tx Interval (ms) min/max/avg: 1/1000/871 last: 548 ms ago
Uptime: 00:11:46
             My Discr.: 1                - Your Discr.: 6
OurAddr: 172.21.101.81
Holddown (hits): 0(0), Hello (hits): 1000(821)
Rx Count: 824, Rx Interval (ms) min/max/avg: 1/4608/875 last: 20 ms ago
Tx Count: 826, Tx Interval (ms) min/max/avg: 1/1000/872 last: 800 ms ago
Uptime: 00:11:45
             My Discr.: 5                - Your Discr.: 2
OurAddr: 172.21.191.185
Holddown (hits): 0(0), Hello (hits): 1000(816)
Rx Count: 816, Rx Interval (ms) min/max/avg: 1/3944/882 last: 952 ms ago
Tx Count: 822, Tx Interval (ms) min/max/avg: 1/1000/876 last: 488 ms ago
Uptime: 00:11:46
             My Discr.: 2                - Your Discr.: 4
R2#
Of course, the EIGRP adjacencies are up:
R1#show ip eigrp vrf ADMIS nei
EIGRP-IPv4 Neighbors for AS(100) VRF(ADMIS)
H   Address                 Interface       Hold Uptime   SRTT   RTO  Q  Seq
                                            (sec)         (ms)       Cnt Num
0   172.16.160.25           Fa0/1.1518        10 00:16:48    8   300  0  5
R1#show ip eigrp vrf OPS nei
EIGRP-IPv4 Neighbors for AS(100) VRF(OPS)
                                            (sec)         (ms)       Cnt Num
0   172.21.101.81           Fa0/1.1516        10 00:16:55   16   300  0  4
R1#show ip eigrp vrf SUP nei
EIGRP-IPv4 Neighbors for AS(100) VRF(SUP)
                                            (sec)         (ms)       Cnt Num
0   172.21.191.185          Fa0/1.1517        14 00:16:58    8   300  0  5
R1#
R2#show ip eigrp vrf ADMIS nei
                                            (sec)         (ms)       Cnt Num
0   172.16.160.30           Fa0/0.1518        11 00:17:36    4   300  0  5
R2#show ip eigrp vrf OPS nei
                                            (sec)         (ms)       Cnt Num
0   172.21.101.86           Fa0/0.1516        14 00:17:41  124  1116  0  4
R2#show ip eigrp vrf SUP nei
                                            (sec)         (ms)       Cnt Num
0   172.21.191.190          Fa0/0.1517        10 00:17:43    4   300  0  5
R2#
So, the behavior as observed by you is strange indeed. Do your EIGRP adjacencies come up? Would you mind upgrading your IOS to a 15.1M train or newer to see if this is not a software bug? Try avoiding the 'T' trains if possible.
Best regards,
Peter
Peter Paluch
Pato,
One more observation: I am somewhat confused by this output from your show bfd nei detail:
TTR255#show bfd neighbors details
172.16.160.25                      6/0     Down      Down      Gi0/1.1518
Received MinRxInt: 0, Received Multiplier: 0
Holddown (hits): 0(0), Hello (hits): 1000(7452)
Rx Count: 0, Rx Interval (ms) min/max/avg: 0/0/0 last: 80491968 ms ago
Tx Count: 7452, Tx Interval (ms) min/max/avg: 756/1000/882 last: 412 ms ago
             State bit: AdminDown        - Demand bit: 0
             Multiplier: 0               - Length: 0
             My Discr.: 0                - Your Discr.: 0
             Min tx interval: 0          - Min rx interval: 0
             Min Echo interval: 0
I was not able to find out why the "AdminDown" state is displayed, and it seems to be an indication of something that is perhaps causing your problem.
Best regards,
Peter
