BFD question
kriskrs
On Cisco 7600, I've the following commmand:
bfd interval 750 min_rx 500 multiplier 4 - on interface.
Now the service should be migrated to NCS540 with XR, how can be this translated because I don't have option "interval".
Thank you!
Hello @kriskrs,
In Cisco IOS XR, the
equivalent
command for BFD on an interface does not include the
interval
parameter. Instead, you can configure the minimum interval, minimum receive interval, and multiplier using different commands.
bfd template <template-name>
min-interval 750
min-rx-interval 500
multiplier 4
-- Apply template on interface:
interface <interface-type> <interface-number>
bfd mode <template-name>
As concerned bgp instance apply template on the neighbor:
router bgp <AS-number>
bfd all-interfaces
neighbor <peer-IP-address> remote-as <peer-AS-number>
neighbor <peer-IP-address> bfd fast-detect
neighbor <peer-IP-address> fall-over bfd
neighbor <peer-IP-address> bfd template <template-name>
Best regards
7 Replies 7
if you use BFD for BGP there is command under the
router bgp for bfd multiplier and min-rx
kriskrs
I need to use under interface, anyway in both cases, interface or BGP, there is no option
interval
and my questions if it will be up without
interval
option. I mention that on the other side is a customer, I cannot control/change the other end.
bfd minimum-interval milliseconds
bfd multiplier multiplier
Hello @kriskrs,
equivalent
interval
min-interval 750
min-rx-interval 500
multiplier 4
bfd all-interfaces
Best regards
Yes he sure can use
bfd
template under interface.
kriskrs
Very good info, but seems that in my XR version (7.2.2) I don't have this option.
bfd ?
bundle Option for BFD over Bundle
dampening Configure BFD dampening intervals
echo Configure BFD echo parameters
interface Configure BFD on an interface
ipv6 Ipv6 BFD checksum
multihop Configure BFD multihop
multipath Configure BFD multiple path
trap Configure BFD trap parameters
<cr>
In case of using
bfd without interval
it will remain down?
Even under BGP there are no options like template, fall
Thank you
Can I know asr platforms and ios xr ver.
