04-04-2019 06:52 AM
hello all
does anyone know if BFD for DMVPN is supported on ISR4K and if yes which version of software we should use
and if no what can I do to achieve fast convergence on multiple DMVPN clouds?
thank in advance
Solved! Go to Solution.
05-29-2019 03:38 AM
Hello n.bokhar1,
here in the forums we see many issues arising for ISR 4300 platforms caused by licensing.
So the question asked by Georg is not out of context.
Can you post show license all of your device?
About the feature BFD for DMVPN:
the document describing the feature shows clearly that the feature has limited capabilities
see the restriction section
>>NHRP currently acts only on BFD down events and not on up events.
The feauture has been introduced for those DMVPN not using IPSec encryption
>> In non-crypto deployments, spoke can detect hub failure only after NHRP registration timeout but hub cannot detect a spoke failure until cache on hub expires (even though routing can re-converge much earlier). BFD allows for a very fast detection for such a failure.
Are you using IPSec protection on your DMVPN, can you enable DPD dead peer detection ?
What routing protocol are you using over the MGRE tunnel ?
Also BFD has been introduced for point to point networks. DMVPN are multipoint in nature.
In other terms in a DMVPN you will have on the hub one BFD session for each spoke router.
This limits scalability of the DMVPN.
>> A single DMVPN hub with BFD can be scaled to a maximum of 4095 sessions on a Cisco Aggegation Service Router 1000 Series since the number of BFD sessions on these platforms is limited to 4095 currently. Regular methods of scaling DMVPN like clustering, Server Load Balancing (SLB), hierarchical designs, etc still apply. This does not impact DMVPN scale without BFD.
Final note: it is not clear what happens for Spoke to Spoke dynamic tunnels. They are mentioned
>> BFD intervals configured on the peers should be the same in the BFD echo mode for spoke to spoke refresh to work as expected.
The question is the following: would be the Spoke to Spoke tunnel be turned down when no needed as expected or the BFD session between the Spokes will keep it up for ever?
Hope to help
Giuseppe
04-04-2019 07:25 AM
BFD for DMVPN was introduced in Cisco IOS Release 16.3, according to the document linked below:
BFD Support on DMVPN
04-05-2019 11:31 PM
04-06-2019 12:09 AM
check Table 5 of the attached document. BFD is supportted on the ISR4K, you need AX (Application Experience):
Application Experience (AX)
IP Base + Security + advanced networking protocols: L2TPv3, BFD, MPLS, VRF, VXLAN[10] (Bandwidth <100Mbps)
05-29-2019 02:11 AM
thank you very much but the issue is not whether or not ISR 4K supports BFD, it is if it has support for "BFD for DMVPN" it is a different feature and if anybody has ever had any experience using this on ISR 4k?
05-29-2019 03:38 AM
Hello n.bokhar1,
Hope to help
Giuseppe
