BFP flapping with IP verify source reachable-via ANY
sebastien3
Level 4
Level 4
If I enable ip verify unicast source reachable-via any on the interface which is connected to another router, BFD is unstable !
interface TenGigabitEthernet0/3/0.10
description *** To R2 ***
encapsulation dot1Q 10
ip address 10.0.1.1 255.255.0.0
no ip redirects
no ip proxy-arp
bfd interval 750 min_rx 750 multiplier 3
Apr 17 07:59:52: %BFDFSM-6-BFD_SESS_DOWN: BFD-SYSLOG: BFD session ld:2065 handle:8,is going Down Reason: ECHO FAILURE
Apr 17 07:59:52: %BFDFSM-6-BFD_SESS_UP: BFD-SYSLOG: BFD session ld:2065 handle:8 is going UP
Apr 17 07:59:57: %BFDFSM-6-BFD_SESS_DOWN: BFD-SYSLOG: BFD session ld:2065 handle:8,is going Down Reason: ECHO FAILURE
Apr 17 07:59:57: %BFDFSM-6-BFD_SESS_UP: BFD-SYSLOG: BFD session ld:2065 handle:8 is going UP
Apr 17 08:00:03: %BFDFSM-6-BFD_SESS_DOWN: BFD-SYSLOG: BFD session ld:2065 handle:8,is going Down Reason: ECHO FAILURE
Apr 17 08:00:03: %BFDFSM-6-BFD_SESS_UP: BFD-SYSLOG: BFD session ld:2065 handle:8 is going UP
Now if I use ip verify unicast source reachable-via any allow-self-ping BFD is stable ans UP but the counter increments a lot :
IP verify source reachable-via ANY, allow self-ping
22817 verification drops
2138947 suppressed verification drops
0 verification drop-rate
An idea of ​​the problem ?
20 Replies 20
Mark Elsen
            - On which platform (device model) are you experiencing this issue ?
 M.
sebastien3
Level 4
Level 4
ASR 1002/1004 with IOS adventerprisek9.03.16.10.S.155-3.S10-ext
 Take a look on this very good article
https://nsrc.org/workshops/2019/mnnog1/riso/networking/routing-security/en/labs/uRPF.html
In short, by using the command   you are enabling uRPF and the logs confirm
"Reason: ECHO FAILURE"
By using the commamd allow-self-ping you fix it.
About the drops, make sure it is incrementing or it is previuos drops.
Hi @Flavio Miranda
The drops still increment with allow-self-ping... Both routers use EIGRP through this interface.
Hello
Why are you using uRPF with a BFD in this case anyway, using BFD suggest you wish to speed up convergence of some dynamic routing process so appending uRPF doesn't seem applicable
As for uRPF using the  "any"  keyword doesn't like the use default routes, meaning it will allow return traffic on "any" interface as long as there is a route from that destination in the route table, otherwise you need to append the "allow default"
Kind Regards
Paul
Hi @paul driver
Why would uFPF be incompatible with BFD (EIGRP/BGP) ?
What you meaning unstable? Can you more elaborate?
BFD UP/DOWN, see log :
What timer you use ?
timer is good it not low and little bit high,
can you disable bfd echo in both interface in both sides.
interface x/x
no bfd echo
Cisco Doc. for any one see the post later
BFD echo mode and Unicast Reverse Path Forwarding (URPF) are mutually exclusive and cannot both
be enabled on a BFD interface. If you want to configure an interface for BFD, you must disable either
BFD echo mode or URPF.
NOTE:- update us when this issue is solve.
MHM
I used no bfd echo with ip verify unicast source reachable-via any and no more instability.
I admit I don't understand why knowing that BFD does not use echo ?
Drops still increment even with no bfd echo...
show bfd neighbors details => Session state is UP and not using echo function.
Drops still increment even with no bfd echo... <<- what meaning of this ?
can I see
show bfd nei details
NeighAddr LD/RD RH/RS State Int
10.0.1.2 2067/4449 Up Up Te0/3/0.10
Session Host: Software
OurAddr: 10.0.1.1
Handle: 8
Local Diag: 0, Demand mode: 0, Poll bit: 0
MinTxInt: 750000, MinRxInt: 750000, Multiplier: 3
Received MinRxInt: 750000, Received Multiplier: 3
Holddown (hits): 1682(0), Hello (hits): 750(22227)
Rx Count: 4374, Rx Interval (ms) min/max/avg: 3/755/658 last: 568 ms ago
Tx Count: 4376, Tx Interval (ms) min/max/avg: 3/751/658 last: 503 ms ago
Elapsed time watermarks: 0 0 (last: 0)
Registered protocols: EIGRP CEF
Uptime: 00:48:00
Last packet: Version: 1 - Diagnostic: 0
State bit: Up - Demand bit: 0
Poll bit: 0 - Final bit: 0
C bit: 0
Multiplier: 3 - Length: 24
My Discr.: 4449 - Your Discr.: 2067
Min tx interval: 750000 - Min rx interval: 750000
Min Echo interval: 0
