BGP Advertise-map with dual ISP
Haris P
Level 4
Level 4
I have two upstream on my BGP and I want to make failover when either of them goes down . The attached diagram will explain my scenario and the config I did .
I want to acheive the following this
Advertise my Prefix_A thru ISP_A and Prefix_B thru ISP_B in normal condition
Advertise both Prefixes thru ISP_A when ISP_B is down and vice versa
I did the config. as attached on the diagram . Please tell me if I'nm wrong
andrew.prince
Level 10
Level 10
Haris,
To be honest -I think that would be really tricky. What I would do - is just prepend my AS to one of the upstream peers.
That way I can send my AS to both peers, and all my subnets - and just make one peer better than the other.
set as-path prepend 65003 65003 65003
Place the above in with ever route map you want for the secondary peer - and that peer with receve your subnets with an AS cost of 3.
HTH.
