Load balancing on Cisco Router
rechard_hk
Dear All,
How are you doing?
Anybody Could you tell me how to configure load balancing Cisco router or Do you have sample configuration on this?
Note: All interface i used Ethernet only!!
Best regards,
Rechard_HK
spremkumar
Level 9
Level 9
Hi Rechard
Can you revert back on the kinda links (VPN/Internet) on which you are planning for load balancing.
Do throw more light on the setup/topology you have in place out there..
Dear spremkumar,
I'm really sorry, i tried to find the kinda links( VPN/internet) but it doesn't see .
could you tell met the date that he post?
Best Regards,
Rechard_HK
hi rechard
i was asking about the links which are getting terminated onto the ethernet ports out there.
regds
