bgp advertised router bouncing.
v.matiakis
Hi, i have the following problem. I am connected from the one site at the countries internet and from another site to the global internet. The problem is that the countries internet border router advertises a bouncing number o router. Once for example is 90 and next is 70.What might be the problem?
Danilo Dy
You mean traffic bouncing between routers? That could be routing loop.
Maybe you can clarify more and what is 90 and 70?
Dandy
Once it advertises 90 routes and the other 70 router with this number bouncing from time to time.
These two routers in different countries but there is a private link between them using iBGP? Where did they received the routes that they supposed to advertise, from IGP? Can you post the config for both and their connection diagram?
Dandy
