07-30-2018 07:53 AM
I currently have two routers within the same AS.
Those two routers have IBGP session with one (the same) ISP router.
In the objective to control all routes announcement i have implemented rout-maps in&out with the ISP router to apply MED 100 on my primary router and MED 200 on my secondary router. (in+out)
Would somebody be able do confirm me why i cannot see the metric applied to the ISP router using the command "sh ip bgp neighbors x.x.x.x advertised-routes" ?
it seems the command shows only local metric instead of advertised metric.
Thank you in advance
Attached the schema
Solved! Go to Solution.
07-30-2018 03:50 PM
You will not see the metric being advertised when you run the "show ip bgp neigh x.x.x.x advertised-routes" . This is just the pure routes that you are sending your ISP before any policies are applied. You would have to have your ISP verify the metric from their end.
For example:
Here are my advertised-routes:
Network Next Hop Metric LocPrf Weight Path
*> 1.1.1.1/32 0.0.0.0 0 32768 i
Here is my policy:
route-map SET-COMM permit 10
set metric 200
Here is my BGP on the remote end showing the metric:
BGP routing table entry for 1.1.1.1/32, version 23333
Paths: (1 available, best #1, table default)
Advertised to update-groups:
1 3
Refresh Epoch 2
65498
10.232.1.29 from 10.232.1.29 (99.0.0.1)
Origin IGP, metric 200, localpref 100, valid, external, best
Also, you may want to consider as-prepend rather than MED. MED is not truly effective unless the ISP has deterministic-med enabled.
Hope this helps.
07-30-2018 03:50 PM
For example:
Here is my policy:
set metric 200
1 3
Refresh Epoch 2
65498
Hope this helps.
07-30-2018 10:30 PM
