BGP Advertisement to Specific AS Number
Marcin Zgola
Level 4
Level 4
HOw to setup BGP so it will not get advertised to specific AS.
Example:
My BGP AS 1000 and i peer with AS 2000 and 3000. I want to tell BGP AS 2000 not to advertise to AS 100, and 200.
Or i want to advertise my blocks to all internet but i want to make sure AS 100 and 200 wont have my prefix in the BGP table.
thanks
CCIE 18676
mhnedirli
Can you share your config, maybe you can configure as below
ip as-path access-list 1 deny $2000_
ip as-path access-list 1 permit .*
route-map BLOCK permit 10
 match as-path 1
router bgp 1000
 neighbor x.x.x.x route-map BLOCK out
Ip prefix list could help you better, creat prefix list that denied your prefix and permits other traffic.
I got it up and running..
Thank you
CCIE 18676
 Create a "peer-group" where you will add those two AS to the peer-group. And apply "mhnedirli" solution above...
and use :
neighbor <peer-group-name> route-map BLOCK out
