BGP aggregate address and more specific routes
duongla
According to BGP case studies on Cisco website, "if we are aggregating a network that is injected into our BGP via the network statement then the network entry is always injected into BGP updates even though we are using "the aggregate summary-only" command".
(http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00800c95bb.shtml#case4)
I have tried on Cisco 2600 router with IOS 12.2-15.T16 enterprise software and found that the more specific routes were really suppressed. The output of "show ip bgp" showed the more specific routes were suppressed by a symbol "s" at the beginning of each entry.
Anybody knows from what IOS version there has been a change in BGP behaviour like described above. Where can I find a release note for this.
duongla
Harold Ritter
From as far as I can remember, the behavior of the "aggregate summary-only" command has been to suppress all more specific prefixes including those generated using a network statement.
Hope this helps,
