ftp connecttion
nki
my 3620 cisco router has 4 interfaces in 2 modules.
I am connecting a local ftp server on on interface , and my lan is connection to other interface in the same module 1.
I get ip address on fastethernet on module 2 ( ip address dhcp )
I could`nt connect from my LAN to ftp server, and any user from internet couln`t either connect to my FTp server.
Her my config :
Current configuration : 1315 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname porto
logging buffered 4096 debugging
enable secret xxxx.
enable password xxxx
ip subnet-zero
call rsvp-sync
interface Ethernet0/0
ip address 192.168.4.1 255.255.255.0
ip nat inside
full-duplex
interface Ethernet0/1
ip address 192.168.3.1 255.255.255.0
ip nat inside
half-duplex
interface FastEthernet1/0
ip address dhcp
ip nat outside
duplex auto
speed auto
interface FastEthernet1/1
ip address 192.168.1.2 255.255.255.0
ip nat inside
duplex auto
--More--
ip nat inside source list 1 interface FastEthernet1/0 overload
ip nat inside source static udp 192.168.3.3 21 interface FastEthernet1/0 21
ip nat inside source static tcp 192.168.3.3 21 interface FastEthernet1/0 21
ip classless
no ip http server
access-list 1 permit 192.168.4.0 0.0.0.255
access-list 1 permit 192.168.3.0 0.0.0.255
access-list 1 permit 192.168.1.0 0.0.0.255
dial-peer cor custom
line con 0
exec-timeout 0 0
password 7
logging synchronous
login
line aux 0
password 7 login
line vty 0 4
exec-timeout 3000 0
password 7 login
line vty 5
login
end
could somebody correct my config , in order to everybody ( LAN,WAN) connect to my local ftp server.
sig
Richard Burts
Looking at the config that is posted the biggest issue that I see is the lack of routing information. I do not see any static routes, no default route, and no routing protocol. With no additional routing information the router will only know how to reach its connected subnets.
I suggest that you add either a dynamic routing protocol or add some static routes so the router will know how to reach other remote addresses.
Rick
Rick
