BGP Aggregate route VS summarized route
xine xine
Hi !
I would like to understand the difference between aggrgate route and summarized route in BGP concept.  Those 2 concepts look like to do the same thing reduce IP routing table, but when using each other and what is different between both of them.
Thanks a lot !
HI !
     after I had posted this question, I found I had forgot to read one appendix in which route aggregation is explain.  But one thing is not clear to me, the behavior of the router performing route aggregation is it the same with all of it's neighbor (iBGP/eBGP) ?
The next you provide to me did not gave me access, I has able to read one page only, but in which tha naming concept of route aggregation in BGP was available.
Thanks a lot !
