Bookmark
Subscribe
536
BGP aggregation
The_guroo_2
Level 2
Level 2
Guys i have two subnets as under and i want to aggregate them in BGP but dont know what
would be the aggregation address if someone plz help me out....secondly i have to put ip prefix list as well for these networks so what would be that like le 32 etc
192.68.72.160 /27
192.68.72.32 /28
Thanks guys
Giuseppe Larosa
Hello Khan,
you need to write down in binary the last byte and you need to find out the last matching bit in base addresses
160 = 128 +32  ->  1010 0000
32                         0010 0000
the only possible aggregate that covers both IP prefixes but also other possible prefixes is:
192.168.72.0/24   because first bit of 4th byte is different in the two base addresses
this is called a non exclusive summary route
in BGP you can use
router bgp xx
aggregate-address 192.168.72.0 mask 255.255.255.0
if this is not acceptable for you, you should advertise the IP single subnets
Hope to help
Giuseppe
