BGP and HSRP Tracking
jagdev.dhaliwal
Hi All,
Is there any way to track the BGP route for the HSRP failover, I f i have  Multihomed BGP netwrok with Two ISPa and load sharing is configured. and HSRP has two groups configured.
Jagdev
8 Replies 8
Abzal
Level 7
Level 7
By BGP route do you mean default route that ISPs advertising to you? If so, you could track ip route because HSRP support tracking objects.
Give us some more information.
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
From one ISP (ISP-1) I want to learn a specific Subnet (Eg. 200.10.10.0/24) and from other ISP (ISP -2) default route for rest of internet traffic.  But would also learn deafult route from ISP-1 with lower weight for back up.
Jagdev
You can track using ip sla and tracking within hsrp. Something like:
ip sla 1
icmp-echo 10.10.10.10 (BGP peer)
frequency 5
ip sla schedule 1 life forever start-time now
track 1 ip sla 1 reachability
int g0/0
ip address 192.168.1.2 255.255.255.0
standby 1 preempt
standby 1 ip 192.168.1.1
standby 1 track 1 decrement 10
When sla fails, tracking will fail and routing should go through your other isp. Does that help?
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
shillings
Level 4
Level 4
Another method is to not use BGP for outbound failover of the default route, but instead track 2-3 IP addresses within the ISP cloud, using IP SLA echo. This gives you a little more reach into the ISPs network rather than just detecting if your BGP neighborship fails.
IP SLA can be linked to a static route (i.e. default static route.) If a ping repeatedly fails, then the route is withdrawn. Obviously, you'll need a floating static default route via your other ISP, so that it can fail across.
Outbound routing towards ISPs local routes would still use BGP, as would all inbound routing.
Thansk All,
At first place i do not want to track the eBGP peer or any other sytem, I want to use route traking from my Routing table:-
10.10.20.2 -- Next hope IP of PE for ISP1
Ip route 0.0.0.0 0.0.0.0 10.10.10.2 track 100
Means if i am learing route from ISP1 than the next hope IP for the route would their PE router other wise it would be learing from iBGP and would have next hope IP of my CE2's LAN IP
                |--------CE1------------------PE1
ASA---------|
                |---------CE2-----------------PE2
Jagdev
Hi Jagdev,
You can either track ICMP reachability of ISPs eBGP peer or a specific ip route. It depends on your needs.
Example:
track 10 ip route 1.1.1.0 255.255.255.0 reachability
delay down 10 up 10
int G0/0
ip address 10.0.0.2 255.255.255.0
standby 1 preempt
standby 1 ip 10.0.0.1
standby 1 track 10 decrement 10
About a eBGP peer tracking John already showed you of that example.
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
Thanks Abzel,
If use your example can i also use next hope IP, beacuse there will always reachebilty to internet eithe via one or other next hope?
Example:
track 10 ip route 1.1.1.0 255.255.255.0 10.10.10.2 reachability
delay down 10 up 10
Jagdev
It is a good question indeed   there is no option for interface as I know.
But I think it is possible with threshold option.
You may have a try.
https://supportforums.cisco.com/thread/2119326
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t15/feature/guide/fthsrptk.html#wp1185133
Unfortunatelly I don't have so much experinece with such tracking. Particular subnet that you want to track are you redistributing it to IGP?
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
