BGP AS Filtering
jerome.lopez
Here is the scenario .
R2 and R6 are in the same AS 1 . Backbone 2 in the AS254.
AS254 -------- R2 -------R6---------AS 254
Configure R2 such that only AS paths originating from AS 258 are permitted from backbone 2.
Use a filter for this task.
? Configure R2 such that only AS paths originating from AS 255 are permitted from R6. Use a route
map.
? Use separate lists for the two tasks above.
royalblues
Level 10
Level 10
You can use something like this
ip as-path access-list 1 permit ^258$
ip as-path access-list 2 permit ^255$
route-map test permit 10
match as-path 2
router bgp
neighbor filter-list 1 in
neighbor route-map test in
HTH, rate if it does
Narayan
Thanks..
I did this config. But when i put show command Show ip bgp | include 255
It is showing nexhop ip as Bacbone IP ,but it should show R6 ip as the nexthop.
any additonal conf required ??
issue the following command
Neighbor next-hop-self command on R6
By default BGP peer does not alter the next hop attribute when it send an update to another IBGP peer
Narayan
