BGP AS number per VRF
carl_townshend
Hi All
I have a router connected to 2 ISP's and I need to run BGP to each of them, but with separate source AS per connection on my side.
Would this mean I would need to set up 2 separate BGP processes on my router?
cheers
Julio E. Moisa
You cannot have 2 or more BGP AS on a router. BGP allows to have multiple peerings through IPv4 unicast or through Address-family with VRF. For example
router bgp 100
no sync
no auto
neighbor 1.1.1.1 remote 1
neighbor 2.2.2.2 remote 2
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
OK, What if I want to keep the traffic to each site separate?
Would I just use the same AS source number, but then when I create the address families using VRF's will this allow me to keep the traffic separate on the router?
I wont use route target export/import etc
cheers
If you are going to use VRF you can separate the routing tables and if it is not going to be used for an MPLS you can remove the route-targets, for example you can have:
ip vrf A
rd 1:1
ip vrf B
rd 2:2
interface g0/0
ip vrf forward A
ip add 1.1.1.2 255.255.255.252
interface g0/1
ip vrf forward B
ip add 2.2.2.1 255.255.255.252
router bgp 100
no syn
no auto
address-family ipv4 vrf A
neighbor 1.1.1.1 activate
address-family ipv4 vrf B
neighbor 2.2.2.2 activate
The traffic will be isolated from each other, but you need to specify what prefixes will be into each VRF.
