BGP as-path filter for repeated AS numbers
I am trying to implement an AS Path filter for repeated AS Numbers without typing a long list.
For example, in the below statement, I have to define the AS Number 65022 6 times using standard BGP regular expresison.
ip as-path access-list 1 permit 65022 65022 65022 65022 65022 65022
Is there anyway the above command can be written efficiently   ?. for example instead of typing the AS Number 65022  multiple times, can it be written somethinglike "65022{6}" ? .
Thanks for your support.
Franklin
ubsaccount
ip as-path access-list 10 permit ^(600)+
try that
+ specify one or many options. But can I specify the exact iteration?
I honestly never seen it.  Unless someone has some ninja tricks I've never seen.
ideally the pattern "65022 65022 65022 65022 65022 65022" could've been validated using the following expression..
ip as-path access-list 10 permit (65022 ) {5}
But it didn't work.
