BGP AS Prepend and Soft In/Out
johnlloyd_13
Level 9
Level 9
hi,
i have a single site/router with single upstream ISP and i'll be applying AS prepending via a route map.
BGP isn't something i do on a daily basis and just need some advice.
my questions:
1) do i apply the BGP route map in or out?
2) do i perform BGP soft in or out?
route-map AS-PREPEND permit 10
 set as-path prepend 123 123
router bgp 123
 address-family ipv4
 neighbor 200.1.1.1 remote-as 456
 neighbor 200.1.1.1 route-map AS-PREPEND out   <<< DO I USE IN OR OUT?
#clear ip bgp 200.1.1.1 soft in    <<< DO I USE IN OR OUT? OR CAN I JUST USE "soft" THEN HIT ENTER
Hello @johnlloyd_13 ,
if both routers support the route refresh capability you can use the in option without soft keyword
see
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/iproute_bgp/command/irg-cr-book/bgp-c1.html#wp2094373124
According to the command reference you can also use the soft option alone.
Hope to help
Giuseppe
Giuseppe Larosa
the route-map has to be applied outbound = OUT
At this point you should also clear soft out but you can also perform an hard clear if you want.
Hope to help
Giuseppe
thanks!
can i just issue with a 'soft' and it will do both 'in' and 'out'?
see
Hope to help
Giuseppe
