BGP AS range not supported
tayyab110
would like to run BGP with 32 bit (6 digit) AS number but current verion (s3223_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(18)SXF17b, does no support can you anyone confirm the exact IOS that will solve my problem ? I have 7604 having "WS-SUP32-GE-3B 9 ports Supervisor Engine 32 8GE Rev. 4.5" Enginer.
Francesco Molino
To get ASN 32 bits available, you need to upgrade on Release 15.0.1 minimum.
Somebody asked me already that few days ago then I can drop you Cisco link :-)
http://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/113593-config-bgp-using-32bit-ASN-00.html#req
PS: Please don't forget to rate and mark as correct answer if this answered your question
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
