BGP AS-SET
yuchenglai
Hi all,
Does any one know what attributes, other than AS numbers, BGP "AS-SET" option will apply to aggregrate routes?
Also, by default what attributes can be included in aggregated routes when not using the AS-SET option?
Any insight will be helpful.
Thanks!
David
milan.kulik
Level 10
Level 10
you can use the attribute-map command.
See
http://www.cisco.com/application/pdf/paws/5441/aggregation.pdf
But it seems you can set a limited number of attributes only:
MED, local preference,  weight, origin, community (but not additive).
BR,
Milan
