BGP Attribute for outgoing Traffic
alshamlan
Dear,
I am have the attached diagram:
- There is two links between routers.
- I have intiate BGP Session between them. for incoming traffic I use prepend and it worked fine.
Now, my objective to use the BGP to route network 10.8.8.0/29 on link -1 and network 10.10.10.0/29 on Link-2  on normal operation. In case Link one down I want to route network 10.8.8.0/29 to the second link. In case link-2 down, network 10.10.10.0/29 should be routed to link-1.
Which attribute I should use for this and how this can be acheived to deal with the source IP.
Thanks.
MS
24 Replies 24
Thanks Harold,
Please the traffic is not flow as we required 10.8.8.0/29 to have the next hop as 192.168.1.1 and 10.10.10.0/29 to have next hop as 192.168.2.1, any hin on this?
Once this traffic flow work, I will test the IP-SLA.
Morevoer, Can we thing about it to do it from the other router? Since network 10.10.10.0/29 and 10.8.8.80/29 will be destinaiton to the second router??
The initial configuration I provided should work. Can you please post the relevant configuration that you applied. As for load balancing in the incoming direction, this part can be addresses with BGP AS path prepending.
Hi Harld,
See the configuration.
I have created two loop back interface and applied the route map on then for my testing now. instead og having two physical interces.
interface Loopback0
ip address 10.8.8.1 255.255.255.248
ip policy route-map pbr1
interface Loopback1
ip address 10.10.10.1 255.255.255.248
ip policy route-map pbr2
route-map pbr1 permit 10
set ip next-hop 192.168.1.1 192.168.2.1
set ip next-hop verify-availability
route-map pbr2 permit 10
set ip next-hop 192.168.2.1 192.168.1.1
See the ip route
B*    0.0.0.0/0 [20/0] via 192.168.1.1, 2d18h
      10.0.0.0/8 is variably subnetted, 8 subnets, 3 masks
See ip bgp
ROUTER1841#sh ip bgp
BGP table version is 26, local router ID is
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale, m multipath, b backup-path, x best-external, f RT-Filter
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*> 0.0.0.0          192.168.1.1                           0            77887 66556 i
*                       192.168.2.1                           0            77887 66556 i
*> 10.8.8.0/29        0.0.0.0                  0         32768 i
*> 10.10.10.0/29    0.0.0.0                  0         32768 i
Applying the PRB route-map to the loopback interface will not work. To apply PBR to the traffic sourced from the router. you will need to use the command "ip local policy route-map" in global mode. Also, do not forget to remove "set ip next-hop verify-availability" or use IP SLA in conjunction
with it. Aspreviously mentioned, CDP will not work in your case since the router are separated by a switch.
Hi Harold,
It is working with me now when I tested through the physical interfaces not on loopback and removed the (( ip next-hop verify-availability )) . Moreover, I ahve tested the failover also and it worked as we required without any ip sla conficuration which make me suprised. All what I have changed is removed the (( ip next-hop verify-availability )) and kept one next hop on pbr1 as you can see below, Can you please advice how the failover worked without and ip sla? is it beacuse of BGP incoming traffic working fine that influnce the outgoing to worked?
interface Ethernet0/0
interface Ethernet1/0
interface Ethernet2/0
description Link1
ip address 192.168.1.2 255.255.255.252
interface Ethernet3/0
description Link2
ip address 192.168.2.2 255.255.255.252
Senario tested:
1- Both links UP
subnet 1 going through link-1
subnet 2 going through link-2
2- Link-1 DOWN
subnet 1 going through link-2
the failover of subnet-1 to link-2 was approximately 3 minutes.
3- Link-2 DOWN
subnet 2 going through link-1
the failover of subnet-2 to link-1 was approximately 3 minutes.
The failover will work without IP SLA if you shutdown the interface on the internal router. You need IP SLA if you want to test the entire path between the two routers. For instance, if the external router fails, the internal router will not know since it is connected to the switch and not directly to the internal router. That is where IP SLA can help.
Hi Harold,
yes you are right. Therefore, I have to implment the IP SLA. I will do and share the result.
regards
Hi Harold,
Thanks for your guidance,
I have implmented the SLA and tested it is working fine now , below the configuraiton.
interface FastEthernet0/0
description uplink-for-Link-1
interface FastEthernet0/1
interface FastEthernet0/1/0
description Downlink-for-Link-1
interface FastEthernet0/1/1
description Downlink-for-Link-2
track 1 ip sla 1 reachability
track 2 ip sla 2 reachability
## SLA for Link-1 ##
ip sla 1
icmp-echo 192.168.1.1 source-ip 192.168.1.2
threshold 15
timeout 15000
frequency 15
ip sla schedule 1 life forever start-time now
## SLA for Link-2 ##
ip sla 2
icmp-echo 192.168.2.1 source-ip 192.168.2.2
threshold 15
timeout 15000
frequency 15
ip sla schedule 2 life forever start-time now
## Route MAP for Link-1 ##
set ip next-hop verify-availability 192.168.2.1 1 track 2
## Route MAP for Link-2 ##
set ip next-hop verify-availability 192.168.1.1 1 track 1
Hi Alshamlan,
Can you please share with me how to manage incomming traffic by as-path prepend.
Pl share your configuration.
Thanks in ADV,
Dear DC,
router bgp 65517
bgp log-neighbor-changes
network 10.8.8.0 mask 255.255.255.248
network 10.10.10.0 mask 255.255.255.248
neighbor 192.168.1.1 remote-as 65588
neighbor 192.168.1.1 description ### MW-LINK ###
neighbor 192.168.1.1 update-source FastEthernet0/0
neighbor 192.168.1.1 soft-reconfiguration inbound
neighbor 192.168.1.1 prefix-list BFC_IN in
neighbor 192.168.1.1 prefix-list BFC_OUT out
neighbor 192.168.1.1 route-map PEND_32_FB out
neighbor 192.168.2.1 remote-as 65588
neighbor 192.168.2.1 description ###-Fiber-Main-LINK ###
neighbor 192.168.2.1 update-source FastEthernet0/1
neighbor 192.168.2.1 soft-reconfiguration inbound
neighbor 192.168.2.1 prefix-list BFC_IN in
neighbor 192.168.2.1 prefix-list BFC_OUT out
neighbor 192.168.2.1 route-map PEND_24_MW out
ip route 10.8.8.0 255.255.255.248 Null0
ip route 10.10.10.0 255.255.255.248 Null0
ip prefix-list 24_MW seq 6 permit 10.8.8.0/29
ip prefix-list 32_FB seq 7 permit 10.10.10.0/29
ip prefix-list BFC_OUT seq 6 permit 10.8.8.0/29
ip prefix-list BFC_OUT seq 7 permit 10.10.10.0/29
ip prefix-list BFC_IN seq 5 permit 0.0.0.0/0
route-map PEND_24_MW permit 10
match ip address prefix-list 24_MW
set as-path prepend 65517 65517 65517
route-map PEND_24_MW permit 11
route-map PEND_32_FB permit 12
match ip address prefix-list 32_FB
route-map PEND_32_FB permit 13
