03-06-2015 06:13 AM - edited 03-05-2019 12:57 AM
Have a small doubt : what is the difference between BGP attributes AND BGP Communities ?
Solved! Go to Solution.
03-06-2015 09:20 AM
BGP attributes are aspects of the route which are sent in the advertisement such as AS path, and route source. BGP community is a value that you can assign for a prefix as it is being advertised. As such you can say that BGP community is a particular type of BGP attribute.
Rick
04-11-2015 05:49 PM
I am not sure that I fully understand your question. But if you want to set values in the BGP community or if you want to control behaviors based on the community then yes using route maps is the way to achieve these goals.
Rick
03-06-2015 09:20 AM
Rick
03-08-2015 05:20 AM
I am glad that my answer was helpful. Thank you for using the rating system to mark this question as answered. This will help other readers in the forum to identify discussions that have helpful information.
Rick
03-15-2015 11:32 PM
Thanks Rick. can you help me understand how to use "own community values" ?
I know there are two type of bgp communities : "predefined / well-known community values" as well as we can also define our own community values - so my question is how to use / define and implement the own community values ?
03-16-2015 05:05 AM
The community value is advertised to BGP peers to communicate additional information about a prefix and usually to cause some different behavior from the peer about the prefix. So the first step in using your own community is to determine what information you want to communicate about a prefix and what different behavior you want. You then choose a value that you will use for the community.
The next step is to negotiate with your BGP peer to get them to agree to accept and process the specified community and to implement the different behavior.
Then you make the configuration changes in your BGP to send that community value.
Rick
04-11-2015 11:44 AM
One more Q : -
from configuration point of view : is it always has to be thru route-map ?
04-11-2015 05:49 PM
Rick
03-16-2015 07:10 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
It's really up to the two parties, sharing community values, to determine how they wish to use them and what a particular community value means. Some what commonly, the top half of a community value represents the AS the community is for and the bottom half of the community is a weight to apply to route. (I.e. communities are often used to manipulate how traffic will be routed.)
I also want to mention, more than one community might be attached to a route prefix.
