Single HUB with dual ISPs DMVPN
S.ashok S
I wish to implement DMVPN usning single hub, single router with dual ISPs and have 10 remote spoke locations connected single ISP.
Want to create two tunnel interfaces from each spoke, one is primary (ISP-1 at HUB) and another (ISP-2 at HUB)is backup.
Kindly help if anybody implemented the same setup.
Thanks in advance.
Thanks and regards,
Ashok
satya mothukuri
hello,
I guess itz possible. Please go with link below.
http://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/WAN_and_MAN/DMVPDG/DMVPN_2_Phase2.pdf
Ruben Cocheno
DMVPN Phases
Phase 1 (obsolete)
No spoke-to-spoke tunnels
Summarization/default routing at hub is allowed
Next-hop on spokes it´s always changed by hub
Phase 2 (obsolete)
mGRE on hub and spokes
-NHRP required for spoke registration to hub
-NHRP required for spoke-to-spoke resolution
-Summarization/default routing at hub is NOT allowed
-Next-hop on spokes is always preserved by the hub
Phase 3
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
