BGP Authentication with two RR routers
msaltunsaray
Hi guys,
Can anyone tell me that how do we configure BGP authentication with two RR routers?
Same AS, IBGP peering...
My RRs are 7301.
Thanks in advance.
That is great, yes if you apply the authentication into the template it will be applied to all the peers involved into the template, now my suggestion is do that into an authorized maintenance windows because you could lose connectivity with remote peers.
Please check this link:
http://hackingcisco.blogspot.com/2011/05/lab-137-bgp-peer-templates.html
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
7 Replies 7
Julio E. Moisa
The authentication method between to BGP peers is using the command: password, for example:
router bgp 100
neighbor 1.1.1.1 remote-as 100
neighbor 1.1.1.1 password CISCO.
Actually I meant to do this with RR.
Is the configuration same?
Yes, it is the same, there is no other way to authenticate BGP peers.
If you are using address-family is the same way as well.
Is there a way to configure it under cluster instead configuring for each peering?
Yes, there is a way but if you are already using Peer-groups or templates, for example:
Imagine you are creating the initial configuration for your iBGP peerings:
RR server
router bgp 1
no syn
no auto-summary
neighbor PEER peer-group
neighbor PEER remote-as 1
neighbor PEER password CISCO
neighbor PEER route-reflector-client
neighbor PEER update-source loopback0
neighbor 1.1.1.1 peer-group PEER
neighbor 2.2.2.2 peer-group PEER
neighbor 3.3.3.3 peer-group PEER
Now each RR client must create the peering with the RR server with the same password, peer-groups is not required on the client unless you have more than one RR Server in order to avoid many lines.
I have "template peer session IBGP"
template peer-session IBGP
remote-as XXX
description IBGP Peerings
update-source Loopback0
exit-peer-session
If I write authentication under this template, would it be done for all my IBGP peers?
