08-08-2014 12:15 PM - edited 03-04-2019 11:30 PM
Hi All,
One Autonomous system no (eg:1111). how many place we can use..?
eg:India,..etc..how many place we can use..???
Thanks and Regard
Natarajan
08-09-2014 05:32 AM
Hello.
You may use it anywhere (but you must meet routing policy requirements of ISPs you peer with).
But keep in mind, that (by default) BGP doesn't learn prefixes, those have local AS number in AS-path.
08-11-2014 05:17 AM
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
No limit, as far as I know. However, if you advertize the same subnet(s) to different eBGP peers, you should be able to reach the advertized IP space from those entry points.
If you peer with different AS eBGP peers, you'll probably also want to insure your AS doesn't become a transit for them.
08-11-2014 05:40 AM
Private autonomous system (AS) numbers which range from 64512 to 65535 are used to conserve globally unique AS numbers. Globally unique AS numbers (1 - 64511) are assigned by InterNIC .
This means if ur AS falls under the private range then u can use it anywhere and many times.
