BGP | avoid loops with redundant gateway
omz
Hi all
I have a requirement..  "any prefix that originated in any of site will not advertise back to the same site via a redundant gateway"
The sites are multihomed same BGP AS across 4 sites .. 2 CEs connected to 2 PEs .. and there is iBGP between the CEs..
The PEs do as-override .. do the PE's need to do SoO as well? Or as-override is enough?
If the PEs didn't do as-override .. CE's will need allowas-in .. correct?
How to check there are no loops i.e CE routes are not advertised back to the other CE in the same site?
What show commands or debugs can I use to check this?
Thank you
shaps
Level 3
Level 3
You can use allow as in or as overide, on the CE or PE respectively.
If I understand your query about the loop within the site with the two CEs then this shouldnt be an issue as ibgp vs ebgp with regards to routing should overcome this;
You want both CEs to be able to have visibilty of the customer subnets via each other.
